Bolt-On SFC's.....???
Old Jul 27, 2005 | 01:28 PM
Bayer-Z28's Avatar
Is there such a thing? From what I have seen and heard here in the past 8 months, (I have learned a LOT!) the typical SFC attatched from the LCA and to the front SF... welded to the front, right??
Would these work? I figure they bolt to the tunnel brace too.. SLP is loosing my respect, somewhat...
Suggestions? I could use some advice here. I hear the boxed sets are good but they impede ground clearance. My car is not lowered and I don't plan on going lower than the stock height.... Even w/ wheel and spring changes...
Thanx in advance!!
Old Jul 27, 2005 | 02:40 PM
2001NBMZ28's Avatar
Re: Bolt-On SFC's.....???
A friend of mine has SLP LT's and the SLP bolt on SFC's on his car (we installed them in about an hour). I have the BMR boxed, ground clearance isn't an issue at all - and I like being able to lift the whole side of the car at once with a floor jack. IMO your LT's will hit first.
Old Jul 27, 2005 | 03:38 PM
CamaroSS30thAnn's Avatar
the LTs will hang lower than the subframes, hell the y-pipe will hang lower in places than the headers itself
Old Jul 28, 2005 | 01:31 PM
Bayer-Z28's Avatar
Good stuff!
Thanx! I'll prolly get the SLP's. But as far as performance, now.... I would think the tree point attatchments would be a little better?... yeah, neh??
And yeah, the y-pipe does hang rediculusly low in spots..
Old Jul 28, 2005 | 03:45 PM
2001NBMZ28's Avatar
I think you'll get different opinions on which is better, most will say welded are better, but performance should be about the same. The SLP's are more expensive, but then you won't have to pay for any welding and are easy to install. Either way SFC's are a great mod.
Old Jul 30, 2005 | 09:46 AM
ibyourhucklebery's Avatar
there is a guy on ebay that sells weld in and bolt on (just like SLP!).....just buy the weld in and bolt them on...save yourself the 50 -60 bucks and buy the 8 bolts yourself (grade 8). I did..and man there's a diff. Plus with a warrenty, I can unbolt and take back to dealer!
Old Jul 30, 2005 | 09:57 AM
The problems with a "bolt in" are the possibility of the bolts loosening, and of the bolts tearing the sheet metal where they pass through. Your trying to control the relative movement of the front and rear frames. Bolts, no matter how much you tighten them, will allow some "slip" of the SFC relative to the frame. A weld will not. Just a thought.
With a bolt in setup, keep an eye on the bolts.
Old Jul 30, 2005 | 10:41 AM
Greed4Speed's Avatar
Your SFC will not void any warranty except for the parts directly related. Check out the Magnusson/Moss Act.
So being able to remove it for warranty is a mute point.
I say weld it. The extra bracing isn't needed either.
Old Jul 31, 2005 | 02:03 PM
Bayer-Z28's Avatar
Opinions are welcomed... That's a good point..
I'm still concider in the weld in... I can weld, I just need to find the welder first.. If I have on at my next base, I'll do the weld in. Was prolly looking for a reason to be lazy...
Do you weld to the LCA or is it just bolted there?? IF welded, can I get away w/ a storm weld there, or will that weaken the metal punching through it like that??
Two storms and a bead on the top and the sides..
Old Aug 4, 2005 | 09:23 PM
seawolf06's Avatar
it's been suggested to me to bolt the SFC on and then just tac weld them for extra support. that way it's easier to take them off if you sell the car or want to upgrade.
Old Aug 5, 2005 | 02:15 AM
Bayer-Z28's Avatar
Kewl! Thanx again. How does BMR compare to Spohn??
ImNraged
Aug 19, 2018 08:02 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Richardan15
May 30, 2015 08:36 AM
