Want to supercharge but....
Old Jul 25, 2005 | 06:19 PM
fasteddie94's Avatar
Question Want to supercharge but....
I am planning on getting a supercharger withing the next couple of weeks but i had a couple of questions first. I want to buy a kit that i can add on to and change as my demmand for power changes, but Iwould like a quality piece that i can run now and not hurt anything. All I have now are the mods in my sig but i do plan on adding some motor mods as well. What would be a good kit to do this with? Also I have a spare set of heads and an intake manifold in my basement. Would it help to port those without putting in a cam right away? I do intend to rip into the shotblock eventually before I go crazy with it but it won't be right away. I think it will give me some time to get used to the new power before i go out and do something dumb. Plus I've always felt it's no fun to just buy the best you can right out of the gate with no room for improvement. Sorry i droned on. I would just like some advice from the guys that have done this before.
Old Jul 25, 2005 | 10:49 PM
TimbrSS's Avatar
Re: Want to supercharge but....
The vortech S trim and Procharger P600b and P1SC are good starter kits for a stock motor. If you are on a tight budget, you can probably find these used and save some money. These will take you up to around 550rwhp on a budget rebuilt motor, and will make for a fun street car.
If you plan on rebuilding the motor and cranking up the boost later, I'd get a at least T-trim or D1SC. You can keep those turned down enough to be safe on a stock bottom end, and have the possibility of 650rwhp later on.
I originally bought the D1SC with the twin intercooler kit. If I could do it again, I would have just pieced together my own kit, and would have ended up with a better intercooler for about the same price.
Old Jul 26, 2005 | 04:04 PM
guardrail's Avatar
I have a P600, its a good intro unit, I'll eventually go bigger but for now its plenty of extra for me. You might as well budget in a rebuild because its gonna happen sooner or later...you'll want to push more boost or something. So you might as well plan for it now.
Old Jul 26, 2005 | 06:07 PM
JustNO's Avatar
With your D1SC how much psi did you use ?? How is your drivability?
For a fully forged 383cid engine with 210cc AFR heads is it waste of money to go smaller than D1SC ?? Drivability is important because its a daily car ,so how much psi ? and what specs of cam should be? (now 237/245 584/589 113lsa)
Old Jul 26, 2005 | 06:42 PM
Thanks guys. It looks like i am going to build the block first and then put on a blower down the road. Everyone i talk to say the shortblock can't handle it for long so there's no sense in blowing it up and hurting something else.
Old Jul 26, 2005 | 07:33 PM
Everett's Avatar
i just got done installin a p600b ati procharger on my 97 z28 the moter is lightly moded and it runs great better than i ever thought i would also like to thank the menbers of this board for there help.
Shane
Old Jul 26, 2005 | 10:31 PM
TimbrSS's Avatar
I ran between 8-10# on stock bottom end, unported LT4's, and hotcam with a 4" pulley.
yeah, for the 383, get at least a D1SC, look into F1.
Other than the whine, you cant even tell it's on the car till you get into the boost.
standard blower cam is XE 224/236 114.
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
rideordie
Sep 7, 2015 08:22 AM
