Rear axle play
Old Jul 22, 2005 | 02:02 PM
camarocrzy's Avatar
Question Rear axle play
Recently i put a new rear end on the car and ever since ive been hearing this clunk from the rear whenever i go over any little bump,you can actually feel it if you put your hand on the floor behind the passenger seat. I took the car to a shop to see what the problem was. The mechanic told me i have too much play in the rear axle which causes the clunking noise when i go over any little bump. If this is the problem how can i fix this? He said i need new gears. im just really p****d!
Old Jul 24, 2005 | 02:27 PM
roguedriver's Avatar
Re: Rear axle play
Get under there and make sure nothing is bumping the floor board. If something is, you should see some marks on the floor board from what ever is hitting (paint, dents, scratches ect). If it is slop in your rear, I would guess it's probably backlash thats too far out. You wouldn't need new gears for that, but you would have to pull the cover and reset up for proper backlash, which is just a matter of reshimming the carrier. Make sure you have everything tight back there too (torque arm, shocks, sway bar ect...). Hope that helps.
Ken R.
Old Jul 24, 2005 | 02:57 PM
2001NBMZ28's Avatar
Re: Rear axle play
If the entire rear was replaced make sure everything is tight, especially the torque arm and LCA bolts.
Old Jul 24, 2005 | 07:39 PM
camarocrzy's Avatar
Re: Rear axle play
The mechanic could move the axle around in the carrier on the passenger side, thats what i think the noise is. What makes it that loose,bearings?
Old Jul 24, 2005 | 10:36 PM
Re: Rear axle play
How could he move it around? Just in and out only by pulling and pushing on the tire or axle or just all around movement?
Old Jul 25, 2005 | 07:59 AM
camarocrzy's Avatar
Re: Rear axle play
He could move it in and out and it would also move up and down,which causes that horrible clunking noise.
PROJECT X
Apr 17, 2015 12:13 AM
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Jan 3, 2015 07:22 PM
rockync7
Jan 1, 2015 05:10 AM
