Mercedes New "Big Block:" All of the details on the 6.2 liter V8
Old Jul 22, 2005 | 12:04 PM
redzed's Avatar
http://www.germancarfans.com/print.c...3.001/lang/eng
Originally Posted by GermanCarFans
Cylinder arrangement
V8
Cylinder angle
90o
Valves per cylinder
Displacement
6208 cc
Bore/stroke
102.2/94.6 mm
Dist. between cylinders
109 mm
Compression ratio
11.3 : 1
Output
375 kW/510 hp at 6800 rpm
Output per litre
60.4 kW/82.1 hp
Max. torque
630 Nm at 5200 rpm
Torque per litre
101.5 Nm
Maximum engine speed
7200 rpm
Weight (dry)
199 kg
Power-to-weight ratio
1.88 kW/kg
Here's the scary part:
The rumor is that this 6.2 liter (which AMG will market as a 6.3 liter) is going to replace both the supercharged 5.4 liter (S55, E55 and SL55 AMG) and the normally aspirated 5.4 found in the SLK55 and CLK55.
It seems very possible that the new Corvette Z06 might just be outgunned and (undercut on price!) by an upcoming Mercedes SLK63 AMG.
Before anyone scoffs, it should be said that the current SLK55 AMG is more than a match for a current Corvette Z71 roadster - both in price and performance.
Old Jul 22, 2005 | 12:09 PM
MissedShift's Avatar
Re: Mercedes New "Big Block:" All of the details on the 6.2 liter V8
I'll believe the outgunned part...
Ill believe the undercut part when I see it. Dollars to doughnuts that if it IS cheaper, its within $500.
Old Jul 22, 2005 | 12:14 PM
1990 Turbo Grand Prix's Avatar
Guess I didn't realize that they had and off road package for Corvette.
Old Jul 22, 2005 | 12:29 PM
stars1010's Avatar
Yeah man it comes with a 5 inch lift, 4wd and all terrain tires!
Old Jul 22, 2005 | 12:56 PM
SRFCTY's Avatar
I certainly beats everything in Nissan's arsenal!
Old Jul 22, 2005 | 12:58 PM
96_Camaro_B4C's Avatar
How much does a new SLK weigh? According to M-B's website, the SLK350 (V6) weighs 3253 lbs. I'd imagine that adding the V8, bigger wheels/tires, extra luxo junk, etc. would push the weight of an SLK62 over 3400 lbs (maybe approaching 3500). So if the engine makes 5 more hp and 10 less lb-ft than the LS7, in a car that weighs more than the 3150 lb Z06, and will come only with an automatic transmission...
It will be another fast offering from AMG, but I think the Z06 will be just fine. Besides, it isn't like the two are exactly direct competitors...
EDIT: Just looked up the current ('05-'06) SLK55 AMG. IT weighs 3420 lbs (say 150 to 200 more than a C6 Vette), and with the N/A 5.5L, makes 355 hp/379 lb ft, and comes only with the seven speed auto (though the website lists the ratios for the five speed ). The Vette makes 400/400 and comes with a six speed manual.
For reference, the (previous generation) 5 speed auto SLK32 AMG had 349 hp from its supercharged V6, and stayed neck and neck with the 350 hp LS1 C5 convertible. That SLK weighed 3220 lbs, according to M-B/AMG.
Old Jul 22, 2005 | 02:41 PM
centric's Avatar
199kg = 440 lbs
That's a pretty impressive weight for a complex OHC design. It's still about 50 lbs more than an LS7, though.
I'd be interested in the exterior dimensions vs. the LS7.
Old Jul 22, 2005 | 04:13 PM
PacerX's Avatar
Originally Posted by centric
199kg = 440 lbs
Dressed vs. not dressed is the issue.
Basically, with an engine, you can post whatever numbers you want to post for mass by adding or removing the accesories.
"Fully dressed" used to mean everything necessary for the engine to run except for the battery, radiator, water hoses and fuel lines. A power steering pump or AC compressor would not be included since the engine doesn't need them to run.
Old Jul 22, 2005 | 04:20 PM
Threxx's Avatar
The 7-speed automatic that Mercedes is currently using is capable of shifting faster and more efficiently than any manual transmission driver recorded from what I've heard. And with the manumatic settings it's probably nearly as effective for road-racing as well.
I don't think this new motor will be a Z06 killer since none of those models will be close to as light, and certainly not nearly as good of handling... but it's still amazing to see Mercedes come out with something that will probably be nearly as fast as the new Z06 for roughly the same price.
Kinda of apples to oranges with a nice comparison in the middle.
Old Jul 22, 2005 | 05:24 PM
HAZ-Matt's Avatar
How many performance automatics don't shift faster than humans?
Old Jul 22, 2005 | 11:19 PM
Threxx's Avatar
Any car that can be driven faster with a manual when a very talented driver is at the helm than it can with the automatic version would qualify easily. The large majority of cars are still that way in my experience... even if it's only for the edge that parasitic drivetrain loss gives the manual over the auto.
Old Jul 23, 2005 | 12:20 AM
HAZ-Matt's Avatar
That's all well and good but that isn't because of shift speed. Number of gears, less weight, less loss... but that isn't the point:
Now I don't know what shifting more efficiently means, but I do know what shifting faster means.
Old Jul 23, 2005 | 11:16 AM
mr00jimbo's Avatar
If Mercedes builds this car as fast as a Corvette for Corvette money then it's a sad day for GM.
The Corvette has always had its downsides overlooked by its performance bargain.
Old Jul 23, 2005 | 12:00 PM
RussStang's Avatar
I bet they will call it the SLK65, regardless of displacement. SLK63 doesn't exactly roll off the tongue.
Old Jul 23, 2005 | 05:34 PM
Gold_Rush's Avatar
The current 355hp SLK55 is pretty quick. It already posts 4.5 sec 0-60 and 12.8 sec 1/4 miles and that's with 355 horses. I can't imagine how much quicker it would be with the new 510hp 6.3L.
As it stands, the current SLK55 carries a $62.5k price tag. I'd be surprised if an SLK63 comes in at that price.
