Anyone ever replace AC Compressor Clutch bearings?
Old Jul 21, 2005 | 08:18 PM
1996LT1NY's Avatar
I just picked up a 94 V6 Camaro that suposedly had a bad engine. After I got it home I put a battery on it & fired it up only to find that the engine is fine & that it's the AC Compresor clutch bearings that were making the noise The AC still blows cold so other than the bearings it seems fine.
I had bought this car just to use as a race car, but since it runs pretty well I'm thinking about using it for a little while as is first but I don't really want to blow $400 on replacing a compressor for a car that will be getting stripped this winter anyway. I noticed while looking for parts prices on RockAuto they sell replacement clutch bearing assembly which is only about $20 which is a heck of a lot cheaper than getting a new compressor.
Anybody here ever replace the bearings? I'm wondering if it's a royal pain, if not I will do it & have a little fun with the car this summer before taking it apart.
Thanks!
Old Jul 21, 2005 | 10:51 PM
HBHRacing's Avatar
Re: Anyone ever replace AC Compressor Clutch bearings?
It's not worth the rapair. Replace the entire compressor.
Old Jul 23, 2005 | 04:00 PM
1996LT1NY's Avatar
It took me about an hour& a half & cost under $22 ... it was worth it
Old Jul 23, 2005 | 05:36 PM
HBHRacing's Avatar
you will change your mind when the whole compressor destorys itself again/
Old Jul 23, 2005 | 08:49 PM
rngilliland's Avatar
I had an a/c clutch bearing replaced. Still works fine 40000 miles later.
Old Jul 24, 2005 | 01:15 AM
HBHRacing's Avatar
for every one of you it works for, there are 50 others who have dead compresors within a month. I hope that it doesn't happen to either of you but the odds are indeed against you.
Old Jul 24, 2005 | 06:48 PM
camaroKid223's Avatar
iv got a compressor i may be willing to sell if anyone needs
Old Jul 24, 2005 | 09:45 PM
1996LT1NY's Avatar
Unless it happens right away I don't think I will be changing my mind. I do thank you for your wonderful insightful opinion though If it fails this summer I will look you up & let you know you were right... meanwhile I can be found freezing my butt off with about $350 burning a hole in my pocket
BPS
9
Mar 5, 2015 10:51 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
HectorM52
Jan 30, 2015 11:08 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
