ATI bypass valve (vent to atmosphere only) questions/info
hey everybody
Is there any benifet from keeping your maf in the stock position and useing the vent to atmosphere bypass valve compared to rlocating the maf and using the bypass valve that comes with your ATI kit???can you see more boost or lower air intake temps??thanks for your help im new to boost
scott
scott
Re: ATI bypass valve (vent to atmosphere only) questions/info
What KS91Z28 said is true but if you vent to ATM after the MAF then you are venting metered air. The computer thinks this air is entering the engine and adjusts for fuel accordingly. However the air is being purged rather than being recirculated. If you want to vent to ATM then do so before it is metered...So you would have to relocate the MAF.
-Scott.
-Scott.
I currently vent to atmosphere and I hate it
Too loud and blows dust everywhere including the engine bay etc
I'll be recirculaing it back in just to keep it quiet
Venting to atmosphere will definitely keep the air temps lower as the constant fresh air keeps the inlet tract cooler. The only problems are noise (if this happens to bother you) and also the fact that your car is now a street vacuum. The charger will now flow a ton of air continuously through the air filter requiring very frequent cleaning.
ati wants $400 for their bypass thats pricey...can I use another one besides the ati...if so what brand and where can I find it??thanks for your help
is there any other ones I can use??does anybody have pics of there setup with the maf in the stock location?thanks for your help guys
anybody running a diffrent bypass on their ATI??
You can get the ATI race bpv cheaper than 400. Still not as cheap as the mondo but still. Only thing that sucks about the ati is it's only in red.
How much can that mondo bypass support anyways?
The Mondo valve is suppose to be mandatory for anything over 10psi... that thing is huge! The opening on the mondo valve is as big as the volute on the Vortech... which is around 3 inches! I think there is a picture floating around somewhere.
-B
-B
