Possible to change tie rod ends without a front end alignment?
Old Jul 5, 2005 | 02:45 PM
Cerwin Vega Fan's Avatar
Question Possible to change tie rod ends without a front end alignment?
I know supposedly if you mark the threads you can change the tie rod ends without having to do a front end alignment. I have also heard that it is possible to get the tie rod ends back in the exact spot. I was wondering if I could get some feedback, do you think I will need to have a front end alignment done once I change my tie rod ends if I mark the threads?
Old Jul 5, 2005 | 03:23 PM
Joe 97RA's Avatar
Re: Possible to change tie rod ends without a front end alignment?
I've done it by having the car on ramps, not with the wheels unsupported. Be sure to put the steering wheel in the centered position. Marking the threads helps, but sometimes due to the differences in the tie rod manufacturer that may not always work. By carefully rotating the outer tie rods onto the inner rods you can do a trial and error as to whether it bolts back to the spindle. While I've done it before, I would still recommend that the alignment be checked....... that way you can see if it is out rather than simply having an alignment done.
Old Jul 5, 2005 | 09:53 PM
romoranger's Avatar
i have gotten pretty darn close, but still got one anyway.
Old Jul 6, 2005 | 12:29 AM
revtime's Avatar
Marking the threads or counting the turns as you remove the tie rod end will get you very close.....close enough to drive to get an alignment.
willie-d-nice
Feb 13, 2015 06:40 AM
Collector Car
Jan 5, 2015 10:58 AM
Hurin
Dec 13, 2014 07:38 PM
siguy
Nov 27, 2014 10:07 AM
