PCM question
PCM question
I got my PCM back from shop after reprograming for mods,I was told
that after disconnecting the battery positive to reboot the computer,
then start and let idle for ten minutes.This is after new cam and headers
with catback.After doing this car will surg at idle and stall sometimes.
Do I need to have it reprogrammed?It does run great with throttle.
It is a GM off road milder cam.
2002 Z28 M6
2002 Z28 M6
Re: PCM question
Re: PCM question
You can also reset the PCM by:
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
Resetting the PCM won't lose your tune - There's also an "idle relearn" procedure you can try if you still have problems.
Wait 5-10 min
Turn ignition off
Replace fuses
Re: PCM question
Wait 5-10 min
Turn ignition off
Replace fuses
Wait 5-10 min
Turn ignition off
Replace fuses
It seems to be getting better very slowly,Do you know what the idle
relearn procedure is?
2002 Z28 M6
Re: PCM question
I looked it up - not as involved as I had remembered (for the 00-02 M6 cars). Yours should be OK by now though, except for the AC controls it's pretty much the same thing your tuner said to do.
02 M6 Idle Relearn:
Turn car off
Restore the PCM battery feed
Turn off all AC controls
Trans in neutral/block wheels
Start engine
Allow coolant temp to reach 176*
Idle engine for 5 min
Turn car off for 15 secs
02 M6 Idle Relearn:
Turn car off
Start engine
Deadbolt24
Jan 19, 2015 01:29 PM
