Rough idle...poor mpg....no codes
Old Jun 23, 2005 | 08:32 PM
cralarcon_IROCZ's Avatar
Unhappy Rough idle...poor mpg....no codes
I took my camaro to a local dealership to take care of some repairs. My engine has been idling kinda rough lately...and I only get 200 miles per tank. I've changed my pluges to tr55ix and put in some msd wires. plugs were gapped at 0.060 and then changed to 0.040 but my mpg didn't improve. The dealer said that there wasn't anything wrong with my car. they drove it with a computer hooked up to it and said the the fuel curve was good....they said something else was good but I don't remember what it was. any ideas what the hell could be going on.
I bough the car used from a gm dealer. since i've purchased the car i changed the fuel filter, air filter, plugs, and had one o2 sensor changed by the dealer. wtf is going on here...could it be my maf screwing up...but not enough to send a code???
Old Jun 24, 2005 | 02:35 AM
RMC_SS_LDO's Avatar
Re: Rough idle...poor mpg....no codes
Without hearing anything, I'd recheck all of the plug wires. Easy way to verify you're firing on all cyl's is to pull one at a time at idle. If you pull one and note no change, you found your bad wire.
Prob not the issue, but a quick and cheap check. Been burned (not literally ) by bad wires more than once....
Later,
Allen
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
Chet1185
Apr 26, 2015 04:07 AM
Iamherefornow
Jan 26, 2015 04:57 PM
91Bird305
Aug 5, 2002 01:39 PM
