t56 swap - wiring reverse lights?? type on alex's guide?
Old Jun 21, 2005 | 01:09 PM
sabre81's Avatar
t56 swap - wiring reverse lights?? error on alex's guide?
says... ". Next, the 16 guage brown and green wire needs to be wired to the reverse light connector. Test this first by connecting them together. If the reverse lights do not turn on, find out what the problem is before continuing. Otherwise, connect them to the reserve light pigtail which plugs into the driver side connector on the tranny. Polarity is not relavent here."
Isnt the reverse light plug on thr passenger swide of the tranny??? according to http://afrashteh.com/tranny_pics/sen..._locations.jpg it is.
Old Jun 21, 2005 | 02:50 PM
rngilliland's Avatar
Re: t56 swap - wiring reverse lights?? type on alex's guide?
Yes it is on the passenger side.
Old Jun 21, 2005 | 03:00 PM
sabre81's Avatar
ok and one more thing, i transfer the blue switch with the two connectors on my old pedal assembly to the new one right? Along with the other white switch for the brake and the black clutch switch correct?
Old Jun 22, 2005 | 06:39 PM
jsz28's Avatar
What blue switch are you talking about. Yes you transfer the two switches from you brake pedal assembly to the other one.
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
nballisru
Dec 14, 2014 05:01 PM
Jul 4, 2005 05:00 PM
