Weird vibrations
Old Jun 21, 2005 | 08:26 AM
Usmuscl398's Avatar
Weird vibrations
Just got done installing my full around custom audio and went to crank her up and she fired up fine then i went to let out the clutch and felt some weird vibrations and it made a horrible sound, hard to describe. But when its let out the pedal shakes a lil and the center console vibrates, and i noticed now that it has a leak bak right before the Y goes to one on my exhaust, could this b a tranny mount that yanked my rear main out?!
Old Jun 21, 2005 | 09:59 AM
Usmuscl398's Avatar
Re: Weird vibrations
O and this only occurs while the engines on and engaging the clutch while in nuetral, i dont want to have to take it to someone, and am really worried, im supposed to be dynoing it friday with my current setup and a MADZ28 tune!!!
Old Jun 21, 2005 | 01:54 PM
Usmuscl398's Avatar
Someone I Really NEED HELP
Old Jun 21, 2005 | 02:52 PM
sabre81's Avatar
check that tranny mount and make sure its in tact. Your going to have to remove it btw. When mine broke a while back, you couldnt tell with it on the car. Once i removed i found that i could pull it apart with my hands very easily. check it out
good luck
Old Jun 22, 2005 | 11:31 AM
Usmuscl398's Avatar
Im pretty sure its not the tranny mount, it does it when decelerating from high rpm (say going to 30 in first then puttin disengaging the clutch and it makes this werid grindingish feeling, it does it into third to and a lil bit at idle when not moving, is it a bearing?
Nayr
Mar 3, 2023 08:34 PM
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
