thermostat in boiling water question..
Old Jun 16, 2005 | 11:30 PM
Donohue96M6Z28's Avatar
my car was getting hot, so i put in a new thermostat hoping for a cheap quick fix, my car has been cooler, but just out of curiousity, i put the old thermostat in boiling water to see if it would open or not, and it stayed shut, does that mean that my thermostat was bad? or is that not an accurate way of testing? thanks
Old Jun 16, 2005 | 11:59 PM
trans9_5am's Avatar
Re: thermostat in boiling water question..
Unless you had a thermostat that was a higher temp than boiling water, yes it means it was bad Or atleast i think you can do it this way
Brandon
Old Jun 17, 2005 | 07:39 AM
The thermostat should have opened long before the water was boiling.
Old Jun 17, 2005 | 10:14 AM
00ls1's Avatar
yup bad stat for sure
Old Jun 17, 2005 | 01:31 PM
What is the elevation where you boiled the water? That will affect the temperature of the water. Higher the altitude, the lower the boiling point.
Old Jun 17, 2005 | 01:58 PM
trans9_5am's Avatar
Very true. What thermostat were you running and what elevation are you at? For instance an elevation of 3000 ft would put the boiling point at around 206 F while an elevation of 14000 would drop it to 186 F. If you had a higher thermostat and live a little ways above sea level, the test would be inaccurate for your situation.
Brandon
Old Jun 17, 2005 | 02:18 PM
The other thing to keep in mind... the rated temp of a t'stat is the temperature at which it BEGINS to open. Typically, it will not be fully open until the temperature reaches about 20*F above the rated temperature.
Old Jun 17, 2005 | 02:27 PM
GetaZforgetGT's Avatar
I was bored so I did some searching.
The Highest point in Texas is Guadalupe Peak at 8,749 feet.
Current barometric pressure in texas...is 29.9 give or take.
At that altitude water would boil at approx. 196 degs
I feel it is safe to assume that his car is not parked at the top of the peak
so we can say the his boiling point would carry a temp slightly higher than that.
Conclusion:
Busted thermostat
Man I love Google
Old Jun 17, 2005 | 02:32 PM
TUNDRKYS's Avatar
How do you know this stuff??
Old Jun 17, 2005 | 03:03 PM
trans9_5am's Avatar
Originally Posted by GetaZforgetGT
Man I love Google
Brandon
Old Jun 18, 2005 | 09:11 AM
QuickSilver02's Avatar
I did the water test with my stocker and a 160 hypertech t-stat. The hypertech opened a lot sooner than the stock one, so the test you did is a good way to evaluate for a broken t-stat.
Old Jun 18, 2005 | 11:39 PM
Conclusion:
Busted thermostat
Man I love Google
dude! i live on top of guadalupe peak!!
thanks for looking that up for me, you must have been VERY bored
thanks guys for the responses, made me feel a little bitter about it, by the way, my car hasnt been getting nearly as hot as it did that day
thanks again
Old Jun 19, 2005 | 10:57 AM
Bayer-Z28's Avatar
Gasoline engine's operating temprature is 210*. Water boils at 210*. When fluid is pressurised it raises the boiling point. If your T-stat is rated at 180*, according to what INJUNEER said above, then your stat will not be fully opened until about 200*...It starts opening at 180*, allowing coolant to flow.....Add in the whole altitude thing and..........ok, I'm getting a headache......
I, personally, get nervous letting my car get that hot. Bad experiences w/ POS car in the past.
Old Jun 19, 2005 | 11:58 AM
Kind of stuff you learn in HS science, if not earlier.....
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
tdigger9899
Sep 7, 2015 10:56 AM
MikeWhitener
Aug 2, 2015 06:17 PM
