center jacking point in front of car?
Old Jun 16, 2005 | 01:52 PM
sabre81's Avatar
Is there a safe place to jack the car up from the front and center? I jack the rear up by placing the jack under the pumpkin. Up until now i was i just used ramps for the front, however im going to need to get the car higher for my t56 swap i believe.
thanks
Old Jun 16, 2005 | 02:07 PM
Re: center jacking point in front of car?
You can jack under the center of the K-member. Use a board or something to help distribute the load, if you don't want to take a chance on making some small dents in the underside of it. The dents won't hurt-just more of a cosmetic thing.
Old Jun 16, 2005 | 07:11 PM
Kataklysm's Avatar
If you want you can jack on what little of a frame the cars have...just do 1 side at a time as high as you want it then pop a stand under that side. Under the k-member is the easiest though.
Dec 4, 2014 11:56 AM
bossco
Nov 29, 2014 10:18 AM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
