Broke U-Joint Cap Connector on rear u-joint. Okay to run without?
Old Jun 15, 2005 | 10:45 PM
BlackLT1_TX's Avatar
On the rear U-Joint where the caps are strapped onto the rear, there is a connector that keeps the caps from falling off. The clips are still there, but the thin peice of metal is broke off allowing the caps to fall off when the staps are not on.
Is it okay to run like this, since it appears the clips on the caps couldnt get by the straps that hold them down, I would think so. I really dont want a cap to come off, so I need a definitive answer.
-James
Old Jun 16, 2005 | 02:06 AM
1racerdude's Avatar
Re: Broke U-Joint Cap Connector on rear u-joint. Okay to run without?
-James
OK to RUN the hell out of it.
Old Jun 16, 2005 | 09:58 AM
madwolf's Avatar
Yea, mine broke too the last time I took the driveshaft off. The rear-end yoke holds them in place tight. I wouldn't worry about it.
calaban
May 18, 2020 06:43 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
