Is anyone using EBC breaks?
Old Jun 15, 2005 | 12:33 PM
UK_chevyV8's Avatar
Question Is anyone using EBC breaks?
Hi, I live in the UK so I do not have much choice when it comes to parts.
My 1999 Z28 front rotors are warping again (3rd time) and the rear pads are noisy so I will need to replace them soon, my choices are:
1/. EBC / Green pads- easy to get hold of in UK and a £100 cheaper
2/. Powerslots / Hawk - Take 3 weeks and will cost £540 ($900)
3/. OEM - easy to get hold of in UK and cheapest
The advice I have had dealers is:
Slotted rotors - make more noise but look good and will last longer
Drilled rotors - may crack so stay away
Get OEM - they may not last long but at least they are cheap
Powerslots - much better than EBC but may not be worth the extra cost.
Please help, should I go for EBC?
Old Jun 15, 2005 | 01:11 PM
Bert02SS
Guest
Posts: n/a
Cool Re: Is anyone using EBC breaks?
I'm due for replacement pads on my '02SS daily driver. I'd appreciate any advice, as well as "da UK guy".
Old Jun 15, 2005 | 01:56 PM
SSpdDmon's Avatar
If you're just replacing pads, I would recommend stock pads or Hawk HPS Street pads. If you're going to replace the rotors as well, I would suggest Brembo blanks. No need to get slotted or cross-drilled rotors unless that's the look that you want. I went with the Brembo's because I was tired of the stock rotors warping every 10~15K miles. Happened on my old SS and on my current Z. The Powerslots didn't make a difference on the SS, so I decided not to waste the money on the Z.
Old Jun 15, 2005 | 02:14 PM
Slappy3243's Avatar
Yeah, I went with autozone blanks and they are working out great, especially for the $38 I paid for each. I used the EBC green stuffs on my old V6 Firebird. It completely ate up my rotors. I doubt it was the pad but more likely the quality of the rotors that I had instead. In any case, I cannot recommend them to you as I don't have enough experience with them. I can recommend the NAPA ceramic pads. I have them on the Firehawk right now with the autozone blanks and it is great. I kid you not when I say these pads have next to NO brake dust. I am still amazed. My rear pads (still stock GM) put out WAY more dust! Not sure if you can get them in Britain though.
Old Jun 15, 2005 | 03:13 PM
gary80vette's Avatar
Hi
I've just fitted a full set of EBC discs and red pads to my 2001 SS here in the UK. They are just so much better than stock. I warped 2 sets of stock and this time upgraded. The EBC discs look good too with dimples and slots.
Gary
Old Jun 18, 2005 | 06:04 AM
UK_chevyV8's Avatar
Originally Posted by gary80vette
Hi
Gary
How many miles have you done on EBC discs and did you get them at a good price?
Old Jun 19, 2005 | 01:46 AM
Bud M's Avatar
I have the green pads. They work fine on the street. I have read that they are not well suited to track use, though. I can't comment on the discs, though but the dimples sound interesting. Got a link for pictures of dimpled EBC discs?
Old Jun 19, 2005 | 04:18 AM
UK_chevyV8's Avatar
Link to EBC, you will find them at the bottom of the page
http://www.ebcbrakes.com/Automotive.html
My dealer gave me a good price so I went for the RedStuff pads
Old Jun 21, 2005 | 06:33 AM
Hi
I've now done about 1K miles on the EBC discs and red pads and they perform perfectly in all conditions especially under hard braking at high speed. I've also noticed a significant reduction in brake dust on my wheels which is an added benefit when it comes to cleaning.
All I need to do now is paint the calipers red to match the pads to give a good cosmetic look.
I hope you have the same positive experience with yours when you get them fitted.
Cheers
Old Jun 21, 2005 | 04:13 PM
UK_chevyV8's Avatar
Thanks everyone for your help,
The rotors and pads should arrive tomorrow and I will fit them over the weekend
I have only ever replaced the front rotors and pads, is it just as easy with the back set? what about the hand break adjustment?
While I am at it I may as well replace the break fluid, is it easy and do I need any special tools?
Old Jun 22, 2005 | 11:59 AM
UK_chevyV8's Avatar
They turned up today and I was expecting them to be Zinc anodised but they are black, is this a mistake, the box says Gold Zink Coated?
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Aug 17, 2015 09:50 AM
Cam's maro
Aug 11, 2015 07:45 AM
