Specs for resurfaced flywheel?
Old Jun 15, 2005 | 12:30 AM
Prince's Avatar
I'm going to be getting the stock flywheel resurfaced for the second time, does anyone know what the acceptable specs are????
Thanks,
Dave
Old Jun 16, 2005 | 08:14 PM
jchevy's Avatar
Re: Specs for resurfaced flywheel?
Find out how much was taken off and then get a shim for the flywheel.
Or Buy the shim first and ask them to take that much material off.
The only shim I could find was .050"
Old Jun 16, 2005 | 08:39 PM
madwolf's Avatar
My local tranny shops and Napa carried .025 and 0.050 shims.
Stock thickness is 1.828.
My flywheel after the second resurfacing was 1.798
I used a .025 and have no problems.
Old Jun 17, 2005 | 06:05 PM
Josh'95Z28conv's Avatar
I used no shims. I just had the flywheel resurfaced, and went with it. All was good, untill my spec stage 2 took a ****
Old Jun 17, 2005 | 06:27 PM
matt65's Avatar
If you can resurface stock consider your self lucky. I had 50/1000 in. taken out of mine just to see if It would turn out. Thanks to the previous owner this was not going to be an option. I was fortunate enough to find one at the GM Stealership for a nominal fee. (~$300)
Old Aug 1, 2006 | 12:05 PM
Blue96z28's Avatar
After a search I've found a bunch of threads where people are asking, but the majority are all older - so in recent years, has anyone figured out the minimum safe thickness for the stock t56 flywheel????
Formula Steve
Sep 19, 2023 08:31 AM
Novo
Jun 14, 2016 02:58 AM
karpetcm
Sep 29, 2015 10:08 AM
Bxlt1
Sep 17, 2015 08:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
