RK Sport air temp module
Old Jun 14, 2005 | 10:36 PM
V8 Slayer's Avatar
Anyone try this thing? Actully work?
http://rksport.com/product/p_010963010/view_detail
Old Jun 14, 2005 | 11:21 PM
deadmeat2004's Avatar
Re: RK Sport air temp module
i have heard only negative things about it...
Old Jun 14, 2005 | 11:48 PM
Bud M's Avatar
It defeats the function of the air temp sensor, tricking the computer into thinking the incoming air is always cold. That sensor might be there for a reason...
Old Jun 14, 2005 | 11:57 PM
V8 Slayer's Avatar
Does it really offset the air temp that much to cause problems?
Old Jun 15, 2005 | 09:47 AM
Bud M's Avatar
No, probably not. On the other hand does it make much difference in performance? Again, probably not. It's a band aid approach to changing the operation of the computer. If you really want gains in that area, get it reprogrammed, or at least just relocate the sensor further upstream where it may be less affected by engine compartment heat.
Old Jun 15, 2005 | 09:55 AM
if you have, or are getting the cold air intake you said before, you can relocate it down to where the filter is. That would be the best spot for it anyway.
Old Jun 15, 2005 | 03:58 PM
Hedzilla's Avatar
There is no need to relocate the IAT, the air doesnt get any hotter going through the tube at all.
All the RKsport thing is, is basically a resistor in a plastic housing. It tells the PCM that colder air is coming in than really is, and the PCM slightly advances the timing. you can do it yourself at radioshak for about $.35
Old Jun 15, 2005 | 09:37 PM
V8 Slayer's Avatar
Does it actully do any harm?
Old Jun 15, 2005 | 10:16 PM
Hedzilla's Avatar
Theoretically, it will lower your gas mileage. Thats about it.
Old Jun 16, 2005 | 09:49 AM
yes... it does help. It is a very comman free mod to do. it gives you about .12hp lol MustangEater is the king of free mods, and if he says it works, and everybody else who has done says go for it, go for it. It will not hurt your reading at all. Only improve it.
Old Jun 16, 2005 | 03:04 PM
Hedzilla's Avatar
It wont even give you .12hp. A while back, everyone thought that the SLP intake for the 93-97 cars was a bad intake, because it was metal. The theory was that the metal made the air hotter as it flowed through, thus giving the IAT a higher reading and retarding timing. Then someone finally actually measured the air at the intake opening and the air coming into the throttle body through an SLP intake, and there was absolutely no difference at all. So moving the IAT sensor is a great way to kill an hour or two, but it will do nothing for your car except add a few excess wires to your engine bay.
Old Jun 17, 2005 | 11:41 AM
camaros_4_lfe's Avatar
we are talking about the radio shack resistor bypass
F'n1996Z28SS
Aug 23, 2023 11:19 PM
squarehead
Jan 15, 2015 07:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
