Problems pulling the trany
Old Jun 14, 2005 | 10:34 AM
Red96Lt1's Avatar
It's almost all of the way off of the splines and the bellhousing is hitting the firewall. I've tried jacking up the front of the motor a little, didn't help too much. Any suggestions? Thanks.
Old Jun 14, 2005 | 10:42 AM
madwolf's Avatar
Re: Problems pulling the trany
Did you try lowering the jack (so that it lowers the tranny and it sits at an angle)? Mine had lots of room and that's with new polyurethane motor mounts.
Old Jun 14, 2005 | 12:37 PM
rngilliland's Avatar
It sounds like you are taking the trans and bellhousing out together. If so you need to remove the trans from the bellhousing and take the trans out first.
Old Jun 15, 2005 | 01:52 PM
Red96Lt1's Avatar
Yeah, I was pulling it with the bellhousing. Ion, did you pull it with the bellhousing?
Old Jun 15, 2005 | 06:05 PM
madwolf's Avatar
Nope, I did it without the bellhousing. That's the way to do it. Same goes for the install.
guruerror
Dec 12, 2020 06:32 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
karnykamaro
Feb 2, 2015 01:37 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
