Difference in size of housing with Diff A/R?
Old Jun 14, 2005 | 12:29 AM
S M R's Avatar
What, if any, difference is there between the size turbine housing on a T series turbonetics turbo compared to the A/R ratio?
Or, if that didn't make sense, Are the external physical dimensions different for a T-series turbine housing with a A/R of .81 compared to a .96 A/R or even an !.0+ A/R and if they are different, how much and in what way?
I have googled my A$$ off, and searched this site, looking for this information but have had no luck.
Basically I want to know if my setup (with a Q trim .81 A/R turbine housing) will have to change if I go to a larger A/R on the turbine side.
Thanks.
Old Jun 14, 2005 | 09:58 AM
JZ 97 SS 1500's Avatar
Re: Difference in size of housing with Diff A/R?
Nothing will be changed..... The link below will explain what is changed when A/R is referenced.
http://www.forcedinductions.com/help.htm
JZ
HectorM52
Jul 30, 2017 11:46 AM
BigWil
Mar 29, 2015 12:24 PM
nosliw
Feb 7, 2015 01:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
CaRParts102
Dec 6, 2014 08:45 AM
