Will 97 Z28 rims fit on a 89 IROC.
Old Jun 10, 2005 | 09:58 AM
JLMZ28's Avatar
I need to move my camaro and the front tire is flat.Will my stock rims from my 97Z work.
Thanks,
Jared
Old Jun 10, 2005 | 11:01 AM
breakmyfootoff's Avatar
Re: Will 97 Z28 rims fit on a 89 IROC.
depends on how far you need to move it. the bolt pattern is the same but they are going to sit inside of the wheel wells quite a bit because of the different backspacing and will rub on everything, not sure if they will even go on. If you need to move it 10 feet you might make it work, but I wouldn't drive it anywhere.
Old Jun 10, 2005 | 11:12 AM
TraceZ's Avatar
I dont think they will even bolt on in front. I recall trying it once and the steering knuckle interfered with the rim.
Old Jun 10, 2005 | 11:15 AM
JLMZ28's Avatar
I have to move it about 10 feet.Wgat do you mean the stearing knuckle??
Old Jun 10, 2005 | 12:08 PM
Z28SORR's Avatar
To make this work you need like 2" spacers. Without them the tires will hit the inner fender well on the rear and the suspension components on the front, like the steering arm (knuckle) where your tie rod connects and the shock strut.
Old Jun 10, 2005 | 12:16 PM
TraceZ's Avatar
If you only have to move it 10 feet, drive it on the flat tire.
Old Jun 10, 2005 | 12:19 PM
JLMZ28's Avatar
It doesnt run
Old Jun 10, 2005 | 12:28 PM
You must have a friend with an s-10 blazer or pickup or an older camaro, or at least a spare that would fit. Surely someone you know would have one. If you still have it the spacesaver spare out of your 4th gen would work.
Old Jun 10, 2005 | 01:05 PM
JLMZ28's Avatar
I do still have it, somewhere in the garage. Thanks for the reply.
Jared
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
