C5-Z06 18x10.5" wheels - Need info for FAQ
Old Jun 8, 2005 | 12:36 PM
The data I have on the C5-Z06 stock and (some) aftermarket 18" x 10.5" wheels is that they have a 58mm offset. That makes the backspacing about 8.00". In theory that will put the inside edge of the tire very close to the inner fender panel on a 4th Gen, indicating its likely there will be some "rub".
If you actually own, and have installed these wheels on your 4th Gen:
-did you have any rubbing of the inner edge of the tires on the inner fender pannel?
-did the jounce bumper bracket interfere with the inside of the rim, when the car was jacked and the axle was at full drop?
-if you had any of these problems, what did you do about it?
-are you "sure" of the exact offset of your wheels?
-did you ever measure the actual backspace?
-do you have photos, showing how deep the wheel sit in the fenders?
Any help would be appeciated. Photos will be linked in the FAQ article.
Old Jun 8, 2005 | 02:39 PM
ced8's Avatar
Re: C5-Z06 18x10.5" wheels - Need info for FAQ
Initially it was rubbing on the inner side of the tire
I purchased a set of longer wheel studs and bought spacers
not sure what the offset was but it was done by a local tire shop
no
No but if you want pics of the car let me know. (They will be shots with the spacers/longer studs)
Old Jun 8, 2005 | 04:42 PM
AW/whiteZ-28's Avatar
-did you have any rubbing of the inner edge of the tires on the inner fender pannel? yes only when the axle is articulated alot, by say going over a big dip at a angle
Yes and only when I jack the rear up, never when driving. I did do some grinding to help the problem a little bit.
I did the BFH mod to get them to stop rubbing during normal driving. I plan on tubbing the rear to help the rubbing that only happens when I have a full load of people in my car. the next is answered above.
yes it said in the auction where I bought them
Nope
The link to my car pics are in the link below the questions. If you want better I can take them just let me know
http://www.cardomain.com/ride/532234
Pages 1 and 7
To help the top of my rear tires are a 5/16 spacer away from lining up exactly with the fender.
I'm going to take close ups today
NOTE: I have worse issues with rubbing than most because I have 335's in the rear, not the normal 295 and 315 others have.
Old Jun 8, 2005 | 05:15 PM
JasonD's Avatar
Admin Emeritus
Talking Re: C5-Z06 18x10.5" wheels - Need info for FAQ
Hey Fred (and Brent)! Remember this?
http://web.camaross.com/forums/showthread.php?t=112950
KYWes
Apr 25, 2015 09:12 AM
DropZ
Jan 15, 2015 10:40 AM
squarehead
Nov 21, 2014 08:02 PM
Dimoncutr
Aug 18, 2002 09:39 PM
JasonD
Jul 15, 2002 02:17 PM
