clutch problems....cant get no straight answers
Old Jun 2, 2005 | 10:48 AM
ky1967stang's Avatar
Angry clutch problems....cant get no straight answers
i have a 95 firebird v6 with a 5 spd. I bleed the cltuch today and it still acts like it has air in it. When you displace the clutch pedal and try to shift into a gear the transmission grinds. if you pump the clutch then shift it there is no noise. my slave cylinder nor the master has a bleeder.
WHAT DO I DO?
Old Jun 2, 2005 | 03:35 PM
Unhappy Re: clutch problems....cant get no straight answers
i just got done going to the auto parts store to buy a master cylinder and a slave cylinder. i bleed all the air out. now i have no transmission at all. i can not get it to go in any gear. before atleast i could pump it up and get it to go into the gears. do you all believe i need a new clutch? I am just bumed out right now not knowing how much money i am going have to sink into this thing.
any help is welcomed guys
thanks
chris
Old Jun 2, 2005 | 04:06 PM
Kraest's Avatar
Retired
Did you replace the pressure plate or just the clutch disc?
Mike
Old Jun 2, 2005 | 04:25 PM
i have not replaced the clutch yet......but the person i bought the car from said that he had a new clutch installed but he had to always double clutch it to go into gear. I thought he didnt bled it correctly so i bought the car thinking it only needed to be bleed. well i went ahead and replaced the master and slave cylinders just to make sure. I followed the instructions that came with them. I made sure i got all the air out.
BUT
the transmission still grinds when you depress the clutch and try to shift. I have no clue what to do or replace.
Old Jun 2, 2005 | 04:27 PM
i called the auto parts store and they said the new clutch kit costs 160$$ but until i know for sure i need it i am not going to buy it.
chris
Old Jun 3, 2005 | 12:47 AM
speed_demon24's Avatar
Are you sure the clutch is disengaging all the way?
NewsBot
Jul 29, 2015 08:10 PM
88IROC_Z
Jul 22, 2015 11:38 PM
Latronaxe
Jul 20, 2015 12:00 PM
Catmaigne
Jul 14, 2015 05:17 PM
Boss002
Jul 9, 2015 03:33 PM
