wow, I never knew blowers sucked so bad
Was researching on S/C kits for my car and found this website......
http://www.turbochargedpower.com/Tur...%20Blowers.htm
I love how they focus only on a superchargers faults and don't say anything about a turbo's MANY faults.
Re: wow, I never knew blowers sucked so bad
I take it you never saw the challenge PTK put out to all the supercharger manufacturers? Also, ever check the rules for NHRA? They limit engine displacement as well as the size of the turbos.
Most of it is true except that they don't take power to drive, sure they do, they restrict exhaust flow
If they didn't then why is it that upgradig from stock manifolds to long tube headers on a turbo car makes no difference?
But I think Turbos are better in all the ways they mentioned blowers blow but are more fun to drive then a turbo car if you mainly drive around at low RPM and want that part throttle response/power.
If they didn't then why is it that upgradig from stock manifolds to long tube headers on a turbo car makes no difference? But I think Turbos are better in all the ways they mentioned blowers blow but are more fun to drive then a turbo car if you mainly drive around at low RPM and want that part throttle response/power.
Originally Posted by Kredz28
I with you man!
I figure if i gonna do it, might as well do it right
Originally Posted by ford
If i could get away from nitrous, id love to build my car with a blower. But i would want crazy amounts of boost
Both of those documents are obviously biased....
Turbo kits ARE more expensive, cost is a factor, as is ease of install, and espicially - the ease of tuning (which depends on the car to some degree as well).
Reliability? Temperatures? Both are just as reliable when done properly, and both generate similar temps. Comon.... Saying otherwise is just crap.
Both have pros and cons, and reading the roots vs supercharger vs turbocharger article (from hot rod was it?) explains those differences very well. They're all very similar in the end, and have different feelings.
If both cars have traction, the supercharger was equated to god pushing the car faster and faster and faster. The turbocharger was equated to god smacking the car really hard and then letting it go. I love the supercharger whine (and feeling), but to me, nothing beats hitting the turbo's spool point, hearing it spin up and the car just stabbing forward.
I love turbo whine and a BOV.... but I gotta say, supercharger whine is much better (aside from the fact that it can be usually heard at idle).
Very nicely put!
Very nicely put!
SpeedJunkee
Jun 6, 2015 04:27 PM
NewsBot
May 10, 2015 08:10 AM
rideordie
May 3, 2015 12:53 AM
