wont shift
Old May 30, 2005 | 01:40 PM
97silvermaro's Avatar
wont shift
heres my setup.... LE3 heads LE2 cam... 1995 LT1 and 4l60e with power servo and 4th gear servo... plannin on shift kit... normal drivin shifts fine... but WOT real hesitant to shift redlines for a while from 1st to 2nd..... will a shift kit fix this since the tranny is seein more power? thanks guys and gals
Old May 30, 2005 | 03:56 PM
jay_lt4's Avatar
Re: wont shift
i dought a shift kit will help you, you probly have some internal trans problems or the program you are running isnt allowing the trans to shift
Old May 30, 2005 | 11:55 PM
Formula2Camaro's Avatar
Re: wont shift
This could be way off, but....
It may be your linkage needs an adjustment. It happened to my buddies camaro before, except it wouldn't shift into overdrive at WOT. Try it, it can't hurt I guess. Here is a link to shoebox's page with instructions.
http://shbox.com/trans/A4_trans_linkage.html
shoebox's page=
Old May 31, 2005 | 09:45 AM
94Zpower's Avatar
Re: wont shift
Your trans has too much power going through it and its staring to slip! I went through the same thing last year with my N20, the trans blew sky high a few weeks later, while racing of course.
Old May 31, 2005 | 01:09 PM
Re: wont shift
how do i fix this? do i have to rebuild or will a transgo help me? i have no knowledge on trannies
Old May 31, 2005 | 01:14 PM
94Zpower's Avatar
Re: wont shift
mine took a rebuild to fix it, once the clutches start sliping its only gonna get worse until the go completely, Frank at CPT did my full race re build for much cheaper that most shops and his trannies are proven ino the 10 sec range so dont worry about the word cheap in his trannies! check the link in my sig for his contact info, or if you have questions he will be happy to help you out!
he is one of the most knowledgable and nicest guys on this board!
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
