anybody else experience this?
Old Oct 17, 2002 | 09:28 PM
Deadcarny's Avatar
i went to change my ignition and plugs so i have everything ready before i spray. i replaced my AC Delco Platinum Rapidfires with autolite 104's and installed a mallory HY-fire VI CD ignition, and at first i felt like i had a miss. i went and took the wires off and then back on to make sure they were all on, the miss got less noticible afterwards. i logged some time on the datamaster and the knock count went up a little bit almost everytime i accelerated (except at WOT). i went and pulled all the plugs (except #7 since i have to pull the header. i will do it tomorrow) and took the gap to .042" and put them back. then i put my stock program back in (slightly modded for spark retard, egr, rev limit, and fans). i no longer feel a miss, but i logged some driving time today with datamaster and was still seeing spark retard (none above 4k RPM's) and it would pick up some knock once in a while. should i keep driving (after i regap the #7 plug) and get some mileage with the Program i put back in there? i did notice that when i first started driving after loading the program, i was picking up lots of retard and knock (even at idle). then after a little while it got less. it is not constant, just once in a while. if i rev the motor and let it run down, it picks up knock. i also notice that the STerms were going lean about 75% of the time before it would pull spark. what do you all say? i am lost! i want to make sure i have all knock issues taken care of before i spray it, even though i have not seen any knock above 4k RPM's and my window switch is not going to open until 4600 RPM and shut off at 5700 RPM.
FredM
Exhaust System
Feb 8, 2016 02:10 PM
Sep 18, 2015 03:46 PM
karpetcm
Sep 15, 2015 11:07 AM
jackpawt883
Aug 26, 2015 11:22 AM
GT what?
Jul 14, 2015 10:17 PM
