In Datamaster how can you tell if your rich/lean? roughly
Old May 24, 2005 | 10:54 PM
DarkHorse's Avatar
I'm running a little lean I think - is there something in Datamaster that will give me a rough idea of just how much?
Old May 24, 2005 | 10:58 PM
Re: In Datamaster how can you tell if your rich/lean? roughly
You can get a very rough indication of A/F ratio from the O2 sensor millivolt readings at WOT. Note the use of the term "VERY ROUGH". Stock narrow-band sensors are not intended to be accurate at the A/F ratios you need for max power/torque. I have some comments on the kind of numbers you might see in my online scanner writeup:
http://members.aol.com/InjuneerZZ/ScanMast.htm
Old May 25, 2005 | 07:49 AM
DarkHorse's Avatar
Thanks Fred
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
