breaking in engine
Old Oct 17, 2002 | 08:45 PM
number77's Avatar
breaking in engine
how do yall break in your engines, and is there any performance gain/loss from doing it wrong
Old Oct 17, 2002 | 09:05 PM
70 Cam Guy's Avatar
Cam break-in is essential for normal hydraulic lifter cams. Roller cams supposedly don't need to be broken in. When breaking in the cam, you will rev up from 2k to 3k rpms for about 15 minutes. You have to make sure you pushrods are spinning also. If break-in isn't done right, you can cause premature lobe wear on the cam.
You will typically take it easy on the car for the first 500-1000 miles while everything seats and loosens up. It is also bad to break in an engine on synthetic oil.
http://www.cranecams.com/instruction...in/camfail.htm
There is a great explanation here. Part B describes an ideal break-in
Old Oct 17, 2002 | 09:40 PM
number77's Avatar
thanks, i never knew about how the cam could be ruined that way, thanks again, i'm just here to learn
cmyname1
Feb 19, 2015 08:38 PM
grabbem88
Feb 13, 2015 03:09 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
dmaastr
9
Jul 1, 2002 02:22 PM
