nitrous in the burnout box ... ???
Old May 24, 2005 | 09:55 AM
QWIK GTO's Avatar
I’ve just finished wiring my new nitrous system and think I may have made a mistake. I didn’t want the toggle switch in the interior for the master arming of the system so I just mounted it under the hood. I’ll have to open the bottle in the trunk anyway before a run so I thought flipping a switch under the hood would be easier/cleaner than having wires coming into the car. Now I’m questioning what will happen during the burnout since the system will be active then. I do have a WOT switch to activate everything and a RPM window is set up from 3000 – 5500. Will the nitrous come on in the burnout box and if it does, will it hurt anything? May be a good way to purge the system … ??? Thanks.
Old May 24, 2005 | 02:33 PM
LT1Squirrel's Avatar
Re: nitrous in the burnout box ... ???
you wont be at WOT thruout the burnout, it'll only turn on at the initial punch to start the spinning
Old May 24, 2005 | 03:36 PM
84 monte SS's Avatar
Not a good idea IMO. Very easy way to mess up and blow the motor.
Old May 24, 2005 | 03:54 PM
526 SS 96's Avatar
Ditto 84 Monte
Old May 24, 2005 | 04:19 PM
EVERESTZ28's Avatar
I 2nd this.
Old May 24, 2005 | 04:33 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
that is how I do it.
i do my burnouts in 2nd gear, and right as I start to roll out of the burnout, I go WOT so the nitrous comes on.. it usually delays for a second, then it comes on and I lift.. its how I purge it. (both fuel and nitrous are purged this way).
Old May 24, 2005 | 05:05 PM
12Second3rdgen's Avatar
That is how a lot of my friends do it, no need to buy a purge kit and nobody knows .
HibachiZ28
Nov 6, 2015 12:53 AM
zk06
Sep 9, 2015 11:39 AM
realistyc
Jul 28, 2015 07:32 PM
Noct
Jul 14, 2015 01:18 AM
Boss002
Jul 9, 2015 03:33 PM
