Turn signal and brake light broblems
Old May 14, 2005 | 12:51 PM
Even10Flow's Avatar
Alright, Last week it rained in my area alot. and i noticed that my driver side rear lens was flooded. All of the light bulbs also went bad. So i took off the lens, drained it out, found the leak and sealed it with silicone. Before i changed the bulbs i let it dry out. I replaced all of the bulbs and the brake light and turn signal still do not work. The other two work fine. Does anyone know why this is?
Old May 15, 2005 | 07:26 AM
Kataklysm's Avatar
Re: Turn signal and brake light broblems
Are the sockets for the bulbs corroded? Usually happens depending on how much water got in and how long it was there.
Old May 15, 2005 | 08:29 PM
Even10Flow's Avatar
Ok i changed the bulbs again. The turn signal still does not come on when im driving, nor does the brake. But when i hit alarm button all of the lights in the back go off. Anyone know why this is?
Old May 16, 2005 | 03:53 PM
TakZ28's Avatar
I have quick question:
How do you change the front turn signal/parking light bulbs on a 2001 Z28?
I just recently got the car and one of the bulbs isn't working. I checked the manual and it's not in there.
Can someone please post how to do it step by step or post a link that shows how it's done?
Thanks.
Old May 16, 2005 | 09:34 PM
Even10Flow's Avatar
anyone
Old May 16, 2005 | 09:40 PM
IRONFIST's Avatar
Have you checked your fuses? You might have blown a few and that could be why your lights arent working.
As for the signal light, I would imagine it changes from under the hood...
If you just look around you could probably figure it out.
Old May 17, 2005 | 04:17 AM
TakZ28's Avatar
After 2 beers I figured it out.
Wasn't too bad.
Old May 22, 2005 | 10:21 AM
Even10Flow's Avatar
sll of the fuses are changed. brake light works...rear driver side turn signal still doesnt work. any other possibilities??
stangspank
Nov 13, 2015 01:02 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
