1997 T56 in a 1993 Z28
Old May 11, 2005 | 07:34 AM
LWillmann's Avatar
Friend of mine converter from an A4 to a T56, but his speedo doesn't work.
I've searched and found where people have swapped rear ends to get the speedo calibrated again, but didn't find anything about using a different year transmission.
What do we need to get to fix his speedo so it works right?
The car is a 1993 Z28, the transmission came out of a 1997.
Old May 11, 2005 | 09:28 AM
1SlowFormula's Avatar
Re: 1997 T56 in a 1993 Z28
I am not a Manual expert and I can't remember how the speedo is calibrated on the 93.. But I can tell you the M6 in 93 has different ratio's then the M6 in 94+ so if the calibration is done through a chip or something make sure you tell the tuner that is a new tranny and not to use the ratio's for 93...
Old May 11, 2005 | 09:38 AM
LWillmann's Avatar
I had heard that the speedo in the 93's is cable driven, rather than PCM driven.
Old May 11, 2005 | 09:54 AM
respectirocz's Avatar
i heard that later model 3rd gens were no longer cable driven, so why would they go back to cable for the 93? i might have my info wrong
Old May 11, 2005 | 10:02 AM
LWillmann's Avatar
I could be wrong as well. But that's why I'm asking here.
Old May 11, 2005 | 11:11 AM
madwolf's Avatar
The speedometer is electrical on 93s, but those ECMs are very limited as far as speedometer calibration is concerned.
If he kept the 2.73s or 3.23s in his car, then he should be able to make it work by swapping in an M6 chip or by having the chip burned with an M6 tune.
Old May 11, 2005 | 11:19 AM
LWillmann's Avatar
The chip has an M6 tune in it, or it's supposed to anyway.
I will have to get under the car and make sure that the wiring for the sensor is connected properly.
I believe that it does still have the stock gears in it, but I'm not 100% on that.
Old May 11, 2005 | 11:23 AM
madwolf's Avatar
Yes, double check all the wiring. A4 cars, like M6 cars in 93 had both 2.73 and 3.23 gears, so there were two different tunes available for them. Which gears does he have? What is the broadcast code on the M6 tune he used?
By the way, I know of another person having the exact same problem.
I'm putting a 97 tranny in my 93, but I'll be converting to a 94 PCM because I have 4.10s in it and I would've needed the speedometer calibration box anyway.
Old May 11, 2005 | 12:02 PM
LWillmann's Avatar
Not sure on what gears he has.
I've been trying to locate info on what wires should connect where for the 93's but I'm not having any luck.
Not sure on the broadcast code. The tune he bought came from PCMforless.
Old May 11, 2005 | 12:20 PM
JKDZ28's Avatar
hey lee, thanks for the help
my gears are 3.23
their was this electrical connecter under the car, if i remember correctly it had 5 prongs.... there were NO plug in for it
i don't know if that makes any diff. with the speedo or not
Old May 11, 2005 | 12:34 PM
LWillmann's Avatar
my gears are 3.23
That 5 prong connector was for the A4's speed sensor I think. So one of those wires needs to be hooked to the T56, and I think the PCM will get speed signal. We'll look at that this weekend.
Old May 11, 2005 | 12:44 PM
JKDZ28's Avatar
sounds good dude, thanks
Old May 11, 2005 | 12:50 PM
Alvin@pcmforless.com's Avatar
All you need to do is just snip off the VSS pigtail from the auto and get a VSS pigtail from a 6 speed car. The prom has to be recalibrated for the 6 speed so if he had it tuned for a AUTO than he will have to have it retuned for a manual.
Its really simple and straight forward. I have a new T56 in my factory auto 93
CobraEatr
Jul 24, 2004 11:37 AM
teedoff59
Aug 8, 2002 01:36 AM
CobraEatr
Jul 29, 2002 11:46 AM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
