LE2 with an ati procharger??
Old May 10, 2005 | 10:59 PM
bondzilla's Avatar
Alright guys heres my dilema, I just recently finished my engine rebuild top to bottom with the le2 heads and cam package. Everything has been beefed up, and i rebuilt the tranny yesturday lol. My question is can i throw a procharger on there i expect i have to do a few more things but i was wondering if its possible and if itll work right thanks-jim
Old May 11, 2005 | 12:14 AM
TimbrSS's Avatar
Re: LE2 with an ati procharger??
If you want to run a SC, you'll want your compression ratio from 8.0:1 to 9.5:1 for pump gas, all depending on how much boost you want to run. This is usually done by changing pistons. The LE2 heads will work fine. If your cam is for a NA application, you will need to switch cams to get the max benefit from the blower.
Old May 11, 2005 | 12:16 AM
n2oblkz
Guest
Posts: n/a
Well, the guys here might wasnt a little more info on your setup. Like, what type of pistons do you have or is it a stock short block? If so, I'm sure the heads were milled so what is your compression ratio? If the compression ratio is too high, it will not work well with a supercharger and may be better suited for a shot of nitrous. Also, the cam that Lloyd uses on his LE2 setup may not be very comatible with a blower setup. I don't know that much about his cam specs (and he keeps them quiet) but it is probably on a 112 LSA and you would probably need at least a 114 LSA cam that is designed for boost.
Old May 11, 2005 | 03:43 AM
TimbrSS's Avatar
Is there an echo in here?
Old May 11, 2005 | 05:50 AM
MEAN LT1's Avatar
Or so we think, I say put the cam in, what ever it is..... and see what she does. Im really interested to see what kind of power your car will put down or better yet what kind of time your run.. But like what was said above we need more info on your setup.
Old May 11, 2005 | 11:22 AM
n2oblkz
Guest
Posts: n/a
Posted by: TimbrSS
Yeah, nobody had replied when I started typing and when I was done and hit "submit", Doooh, the same thing.
Old May 13, 2005 | 10:35 AM
Gripenfelter's Avatar
If you have the LE2 cam you will be bleeding off a lot of the boost.
AviatorDave
Dec 19, 2016 06:35 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95blkss
Sep 22, 2015 03:18 PM
Schul365
Aug 25, 2015 05:47 PM
95blkss
Jul 13, 2015 01:28 PM
