Lug Nut Stud
Old May 10, 2005 | 01:55 PM
camaro777tom's Avatar
Lug Nut Stud
I stripped the stud for one of the lugs. Where can I get another one and what is the pitch/lenght? To remove the old one I just have to hammer it out right?
Old May 10, 2005 | 02:52 PM
Re: Lug Nut Stud
12mm - 1.5, with a 0.50X knurl, stock length is approx 2" (I'll check that when I get home). Probably a "dealer" item, because of the unique knurl diameter. You can hammer it out, but risk damage to the wheel bearings if you beat it too hard.
Old May 10, 2005 | 11:02 PM
respectirocz's Avatar
Re: Lug Nut Stud
i'm a little stuck since i dont know much about wheel studs
i need new ones for my 87 camaro because i'm doing an ls1 brake upgrade, and the dorman part is 610-323
i cant find this part anywhere
the website gives specs for the stud
Attributes:
Type : Serrated Stud
Thread : M12-1.5
Knurl Dia. : 12.80mm
Length : 54mm
Shoulder Length : 8mm
Head Code : 323
i understand the pitch/thread and the length
but i dont understand serrated stud, knurl dia, shoulder length or head code, so i'm having difficulty matching these studs up to the ones autozone offers
Old May 11, 2005 | 01:04 PM
Re: Lug Nut Stud
"Serrated stud" means its a stud with a knurl
12.8mm is the diameter of the knurl, or about 0.504"
The "shoulder" is the length of the knurl (~0.315"), which has to match the thickness of your hub flanges.
Not sure what the head code represents, but it should be a flat head.
That sounds like a stock 4th Gen wheel stud.
Old May 12, 2005 | 03:13 PM
Re: Lug Nut Stud
Yeah, I plan on removing them to replace wheel bearings also so it won't be a problem.
Old May 13, 2005 | 09:51 AM
Re: Lug Nut Stud
thanks for the info injun
its for my ls1 upgrade on my 3rd gen
i found a supplier for dorman only to find that my hubs use a different knurl than most 3rd gen hubs, its about a 14.3-14.5 knurl diameter
so 610-323 wont work for me, but thanks anyway
13qtr
Oct 28, 2016 08:11 PM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
Dams76
Aug 20, 2015 08:28 AM
