T56 won't disengage from engine.
Old May 4, 2005 | 09:59 PM
UkraineTrain350's Avatar
My trans started acting like there was air in the hydraulics. I'd push in the clutch and it wouldn't go into gear without grinding. So I replaced the master and slave cylinders with the GM replacement and it's still doing it. I jacked up the rear and with the engine running and the clutch depressed just pushing the shifter towards any gear makes the tires spin.
It seems like the trans input shaft is binding in the pilot bushing or something. Any thoughts?
Old May 4, 2005 | 10:29 PM
izzyz28's Avatar
Re: T56 won't disengage from engine.
If you replace the master and the slave there is most likely air trapped in the system. To bleed it remove the cap on the reservoir, then unbolt the slave cylinder and hold it diagonally with the line at the highest point. Now slowly push the lunger in by hand and let it return to it's normal resting place. Repeat about ten times and you should be good to go.
Henson071
Sep 18, 2015 04:01 PM
raroz28
Sep 8, 2015 06:10 AM
Slayer
Aug 17, 2015 03:55 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
birdblack
Jul 8, 2015 07:23 AM
