bought a used intake
Old May 4, 2005 | 09:03 PM
305fan's Avatar
(Pontiac Performer) but the problem is--it looks used!
How can I restore the appearance to new?
thanks
Old May 4, 2005 | 11:38 PM
IRONFIST's Avatar
Re: bought a used intake
Let me know how this works for you dude, mine looks like crap too .. haha
Old May 5, 2005 | 07:33 AM
LameRandomName's Avatar
Emory Cloth + Fine Steel Wool + WD-40 + Elbow Grease
Or paint it.
Old May 5, 2005 | 01:52 PM
crazypurgatory's Avatar
Lightbulb Re: bought a used intake
How about sand blasting it?
Everything looks good after sand blasting.
Chris.
Old May 5, 2005 | 04:26 PM
angel71rs's Avatar
I sand blast intakes too to clean them up. If you don't have a sand blaster, local machine shop should do it for about 10 bucks.
Old May 5, 2005 | 06:31 PM
damnyankee36's Avatar
You might try a quick dip in muratic acid. Cleans every type of metal quite well, in fact, too well if you're not carefull, especially with aluminum and other soft metals. Just watch it for a couple minutes at a time.
Old May 5, 2005 | 10:54 PM
DavesLT1's Avatar
best way would be a bit more expensive than sandblasting, but yields better results. use a beadblaster then either go onto a polishing wheel or have it powdercoated. the beads are less coarse and give a smoother surface than sand.
Old May 6, 2005 | 07:40 AM
Dave89IROC's Avatar
I've had success using oven cleaner, but you don't want to leave it on there too long, and you want to rinse it really good
Old May 8, 2005 | 09:45 AM
sheppard00's Avatar
I have min ran through an oven and then a bead blaster at the local machine shop. works quite well cost $20 here
Old May 8, 2005 | 09:58 AM
Dryseals's Avatar
Aluminium, bead blast, always.
transam_388
Mar 15, 2015 11:53 AM
95chwagon
Feb 28, 2015 12:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
99TransAmWS6
Jul 26, 2002 03:18 PM
