Nology?
Old May 3, 2005 | 01:19 PM
350 HRSS's Avatar
Nology?
What is the deal w/ Nology anyway? Is anyone here using any of their products, i.e. wires, plugs, etc.?
They seem aweful expensive w/ a lot of claims.
Thanks for any replies.
Old May 3, 2005 | 02:02 PM
Greed4Speed's Avatar
Re: Nology?
Ricers use them, they must be good.
They seem pretty gimicky to me. Might work best w/ the tornado, turbonator and fuel ionizer.
Old May 4, 2005 | 08:00 AM
350 HRSS's Avatar
Re: Nology?
Thanks for the "reply"
Old May 4, 2005 | 02:19 PM
Camaro_Guru16NY's Avatar
Re: Nology?
hmm never even heard of them, i guess thats a good thing
-john
Old May 4, 2005 | 02:39 PM
Re: Nology?
Rolleyes at me when you're the one asking about gimicky $200 plug wires.
Old May 4, 2005 | 04:14 PM
BadgeZ28's Avatar
Re: Nology?
I saw them for sale and wondered why the big difference in cost. They are supposed to use a capacitor in each wire. Caps are storage devices and in theory, this would increase the spark. It would need to be a quick charge device. Probably similar to photo flash types. I would think a add on box from MSD or Mallory would do the just better and add other features as well.
Old May 5, 2005 | 10:13 PM
slowpoke96z28's Avatar
Re: Nology?
real popular on the LT1 side of the house. they made a big dog coil that replaced the factory coil. that and a MSD 6A or 6AL was good for 10 ft/lbs at the tires. not just a gimmick. as far as the wires or plugs go, i can't vouch for those, but given my experience with their coils, its probably not ALL gimmick
Old May 6, 2005 | 11:52 AM
Re: Nology?
Changing a stock crappy coil like what LT1's have to something with more power is totally different than just changing wires, especially on a coil/plug system. The LS1's ignition system is far from lacking like the Optispark.
Go ahead and spend over $200 for some wires if you want. I'll wait and see the results.
Old May 10, 2005 | 01:06 PM
bunker's Avatar
Re: Nology?
They may help burn more of the fuel in a big cammed setup with tons of overlap thats about all I can think of and only down low like below 2k RPM.
Old May 10, 2005 | 01:24 PM
BadgeZ28's Avatar
Re: Nology?
its pretty easy to charge a new capacitor and show that kind of spark wall. The question is can it do it at 6K RPM and repeat for many cycles?
Old May 15, 2005 | 07:21 AM
Re: Nology?
Found some more info:
"CAPACITOR" EFFECT WIRES with grounded metal braiding over jacket
The most notable of exaggerated claims for ignition wires are made by Nology, a recent manufacturer of ignition wires promoted as "the only spark plug wires with built-in capacitor." Nology's "HotWires" (called "Plasma Leads" in the UK) consist of unsuppressed solid metal or spiral conductor ignition wires over which braided metal sleeves are partially fitted. The braided metal sleeves are grounded via straps formed from part of the braiding. Insulating covers are fitted over the braided metal sleeves. These wires are well constructed. For whatever reason, Nology specifies that non-resistor spark plugs need to be used with their "HotWires." In a demonstration, the use of resistor plugs nullifies the visual effect of the brighter spark.
Ignition wires with grounded braided metal sleeves over the cable have come and gone all over the world for (at least) the last 30 years, and similar wires were used over 20 years ago by a few car makers to solve cross-firing problems on early fuel injected engines and RFI problems on fiberglass bodied cars — only to find other problems were created. The recent Circle Track Magazine (USA, May, 1996 issue) test showed Nology "HotWires" produced no additional horsepower (the test actually showed a 10 horsepower decrease when compared to stock carbon conductor wires).
The perceived effect a brighter spark, conducted by an ignition wire, encased or partially encased in a braided metal sleeve (shield) grounded to the engine, jumping across a huge free-air gap (which bears no relationship to the spark needed to fire the variable air/fuel mixture under pressure in a combustion chamber) is continually being re-discovered and cleverly demonstrated by marketers who convince themselves there's monetary value in such a bright spark, and all sorts of wild, completely un-provable claims are made for this phenomena.
Like many in the past, Nology cleverly demonstrates a brighter free-air spark containing useless flash-over created by the crude "capacitor" (effect) of this style of wire. In reality, the bright spark has no more useful energy to fire a variable compressed air/fuel mixture than the clean spark you would see in a similar demonstration using any good carbon conductor wire. What is happening in such a demonstration is the coil output is being unnecessarily boosted to additionally supply spark energy that is induced (and wasted) into the grounded braided metal sleeve around the ignition wire's jacket. To test the validity of this statement, ask the demonstrator to disconnect the ground strap and observe just how much energy is sparking to ground.
Claims by Nology of their "HotWires" creating sparks that are "300 times more powerful," reaching temperatures of "100,000 to 150,000 degrees F" (more than enough to melt spark plug electrodes), spark durations of "4 billionths of a second" (spark duration is controlled by the ignition system itself) and currents of "1,000 amperes" magically evolving in "capacitors" allegedly "built-in" to the ignition wires are as ridiculous as the data and the depiction of sparks in photographs used in advertising material and the price asked for these wires! Most stock ignition primaries are regulated to 6 amperes and the most powerful race ignition to no more than 40 amperes at 12,000 RPM.
It is common knowledge amongst automotive electrical engineers that it is unwise to use ignition wires fitted with grounded braided metal sleeves fitted over ignition cable jackets on an automobile engine. This type of ignition wires forces its cable jackets to become an unsuitable dielectric for a crude capacitor (effect) between the conductor and the braided metal sleeves. While the wires function normally when first fitted, the cable jackets soon break down as a dielectric, and progressively more spark energy is induced from the conductors (though the cable jackets) into the grounded metal sleeves, causing the ignition coil to unnecessarily output more energy to fire both the spark plug gaps and the additional energy lost via the braided metal sleeves. Often this situation leads to ignition coil and control unit overload failures. It should be noted that it is dangerous to use these wires if not grounded to the engine, as the grounding straps will be alive with thousands of volts wanting to ground-out to anything (or body) nearby.
Unless you are prepared to accept poorly suppressed ignition wires that fail sooner than any other type of ignition wires and stretch your ignition system to the limit, and have an engine with no electronic management system and/or exhaust emission controls, it's best not to be influenced by the exaggerated claims, and some vested-interest journalists', resellers' and installers' perception an engine has more power after Nology wires are fitted. Often, after replacing deteriorated wires, any new ignition wires make an engine run better.
Old May 23, 2005 | 03:58 PM
steelerfan's Avatar
Re: Nology?
WOW !!! And I was just gonna say definitely not worth the money,but without the awesome research.By the way my kid's a ricer & he & his friends said to stay anyway from them,too
jodymoye
Jul 1, 2010 10:33 AM
stewmeistr
Jan 9, 2006 11:30 AM
Ucantcme57
Aug 16, 2004 02:53 PM
96chargedRamAir
Oct 3, 2003 03:21 PM
Mr Z28
Pacific
Sep 7, 2003 01:10 PM
