Car pops out of gear.. or DID pop out..
Old Apr 26, 2005 | 02:31 PM
MasterEvilAce's Avatar
I was racing somebody home, and I swear, or maybe I'm hallucinating (adrenaline rush).. that the car popped out of gear, twice? out of 2nd and one out of third or fourth, something like that..
It's a 2001 SS, M6.. Does that mean the clutch is possibly wearing out?
Old Apr 26, 2005 | 10:39 PM
markinkc69z's Avatar
Re: Car pops out of gear.. or DID pop out..
No, its not your clutch. It would be your synchronizer/hub/slider assembly for the affected gear. The engagement teeth are rounding off and no longer making full contact/engagement.
Old Apr 26, 2005 | 11:00 PM
Bow94z's Avatar
So in a nutshell the car has been beat!
Old Apr 26, 2005 | 11:15 PM
friend said it's possible it wasn't in gear all the way.. I'd rather hear that then anything else :P
car only has 31,000 miles on it.. and really not beaten as hard as most people..
Old Apr 26, 2005 | 11:37 PM
That is possible, if it only happened once and never happens again. But, if the transmission is wearing out as I mentioned it will first happen at high load, then eventually under lighter load, but you might be able to hold it in gear for a while.....then it will really **** you off and refuse to stay in that affected gear no matter what.
Things to watch out for to prevent damage:
Make sure the clutch is at full travel when going into the next gear.
Don't drive around town shifting without the clutch.
Keep/make sure the trans is full of the proper fluid, or an upgrade such as royal purple.
Old Apr 27, 2005 | 12:38 PM
gerard14's Avatar
mine does that after storage for the first 100 miles or so then it fixes itself.
bfmv13trivium
Jan 14, 2015 09:57 AM
hotrod 5210
Dec 22, 2014 07:28 AM
USAirman93
Nov 24, 2014 03:37 PM
Red97LT1
Aug 7, 2002 05:45 PM
FASTFATBOY
Jun 20, 2002 11:27 AM
