amber front turn signal light cover...
Old Apr 25, 2005 | 02:43 PM
sabre81's Avatar
do I have to remove the front bumper to replace the little amber turn signal cover below the headlight? heres a pic just in case(just below the passenger headlight in the pic) --> http://jedi.ks.uiuc.edu/~johns/about...5/p0000041.jpg
A rock or something went through the amber light cover, so now i have a nice hole and a broken turn signal inside.
also, if anyone has one of these for the passenger side ill buy it off ya.
thanks
Old Apr 25, 2005 | 04:55 PM
ImportKILLER's Avatar
Re: amber front turn signal light cover...
No, you don't need to remove the bumper. You'll need either a ramp or a jack to get the front of the car up. From there, it is about 5-8 bolts to remove the plastic splash guard and then two more smaller bolts to remove another splash guard type plastic (you'll need to tug this one a bit, but it will come out).
From there, you just need to remove three nuts to remove the stock orange turn signal.
I could have sworn Brent had a guide on this...check the appearance board. I'm almost positive Brentz has the install guide...it is for a car alarm install but it shows the steps and has pictures
Good luck...won't take too long.
Old Apr 25, 2005 | 05:14 PM
Z95m6's Avatar
thanks
Basically you just take off the panels on the bottom of the car where the CAI filter is.
stangspank
Nov 13, 2015 01:02 PM
squarehead
Jan 15, 2015 07:02 PM
Ryabut98
Sep 3, 2002 11:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
