knock in the rear
Old Apr 22, 2005 | 02:19 PM
marrow's Avatar
knock in the rear
when i slam the gas i get this loud bang like something is loose. ive been told that my gears are going in the rear end. can anyone shine some light on this topic. also what gears are good for the rear. i was thinking slp 3.23 gears. any info will be helpful. thanx
Old Apr 22, 2005 | 08:27 PM
sir dyno's Avatar
Re: knock in the rear
Others have said it could be the y-pipe banging the bottom of the car. Slaming the gas pedal causing the engine to move a little and that in turn moves the y-pipe to bang on the underside of the car or it could be a broken transmission mount, these are very commen to break.
Old Apr 22, 2005 | 08:35 PM
sir dyno's Avatar
Forgot to ask if this happens from a stop then go?
Old Apr 22, 2005 | 11:23 PM
OBE1 95Z28's Avatar
Other sources for banging are loose LCA bolts and loose torque arm bolts (2 long ones mounted to the differential).
Old Apr 23, 2005 | 10:23 AM
marrow's Avatar
if i push the gas nomally then it wont happen but if i push it a litle too much then i get the noise i havent checked the tranny mount yet but i do have the poly urathane mount that i have to put in. i changed the torque arm mount but i still get the noise
HectorM52
Jul 30, 2017 11:46 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
thenewkid
Nov 27, 2014 09:41 AM
