Only 1 tire going bald!!
Old Apr 21, 2005 | 07:35 PM
fre$h's Avatar
sup guys, i have a 96 z28 m6, and ive noticed that only the drivers side rear tire is going bald. the passenger's side is still intact.
Is this normal?
Old Apr 21, 2005 | 07:46 PM
Hetfield's Avatar
Re: Only 1 tire going bald!!
When you take off (or do a burn out) do both tires spin evenly?
Sounds like the posi is starting to wear out causing one tire to take the brunt of the turning force.
Old Apr 21, 2005 | 07:59 PM
Valkyn71's Avatar
I had the same thing happen to me, and my posi was fine.
Must be something that causes them to wear unevenly
Old Apr 21, 2005 | 08:00 PM
fre$h's Avatar
when driving, it's not noticable. is there a way to tell if one side is spinning more than the other?
actually i tried a brakestand, and it started drifting to the side
Old Apr 21, 2005 | 08:03 PM
Hetfield's Avatar
Depends on how it's wearing.
If it is an even, across the board, wear then I am tempted to say check the posi. If the sides of the tire are being worn out, then the camber is probably effed.
Old Apr 21, 2005 | 09:21 PM
DrivinSidewayz's Avatar
wow! howd u change the camber on your solid rear?
id say your tire is spinning when you punch it, do you ever punch it and it feels like you have traction but your revs jump up?
Old Apr 21, 2005 | 09:54 PM
markinkc69z's Avatar
Bald tire are a sign of high testosterone.
Old Apr 21, 2005 | 10:19 PM
Hetfield's Avatar
Sorry, next time I will use the appropriate smiley to communicate my sarcasm.
Old Apr 21, 2005 | 11:27 PM
Blownbird355's Avatar
I think its caster.
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
rideordie
Sep 7, 2015 08:22 AM
Slayer
Jul 4, 2015 03:06 PM
