1994 Chevrolet Camaro Z28, CLEAN, new motor 400hp $7,500!
Old Apr 21, 2005 | 04:00 PM
pattymelt1285's Avatar
For more information call Patrick Moore @ 817-528-1040 OR email pattymelt1285@flash.net
This Camaro was bought in 1999 with 78k miles. The car has been well kept in a garage and maintained with some added performance modifications. The Camaro has a clean title and has never been in any major accidents. The car runs great with a new 355ci. LT1 engine with 10k miles on it. The car made 392 horsepower and 370 torque to the wheels on a chassis dyno.
·The car has never been wrecked, raced, or abused.
·The car is in excellent condition. I planned to keep the car forever and I maintained it that way. I have all maintenance records. I have over $20k in maintenance and performance receipts. The car is always waxed and washed with proper car soap. In fact I just waxed it before I listed the auction with Zymol.
·Some cars have bad luck. I owned one or two like that. Other cars have good luck. This is a good very good car.
·1999 Corvette wheels and Arctic White paint make this one of the best looking sports cars of all time.
Specifications
·1994 Camaro Z28 2-Door Coupe
·5.7 Liter SFI V8 Engine
·4 Speed Automatic Transmission with Overdrive
·Exterior Color: Arctic White
·Interior Color: Ebony
·Miles Per Gallon: 19 City/28 Highway (not bad for a 400+ HP rocket!)
·Approximate Mileage: 109500
Preferred Equipment Group:
·Electric Speed Control w/Resume
·Remote Hatch Release
·Fog Lamps
·Power Door Lock System
·Power Windows
·Mirror Twin Remote Electric
·Leather Wrapped Steering Wheel, Shift ****, and E-brake Handle
·Remote Keyless Entry
·Theft Deterrent Alarm System
·CD player
·Bucket Seats w/Leather Trimmed Seating Surfaces
·Electric Rear Window Defogger
About the Pictures and Condition of the Car
The car is in excellent shape. The car was professionally repainted about 2 years ago at Hillard Ford dealership. The paint is in great shape. I would give it 8.5 out of 10. There is a small crack in the paint in the front of the hood as shown in the pictures. The hood has some VERY small rock chips. The front bumper is in perfect shape, and has been painted with gloss black in the headlight and fog light area. A Suncoast Creations hood has been added, also a RK sport SS spoiler. The interior is in near perfect condition with no stains in the carpet. The floor mats were also replaced with new GM mats. The leather is in great condition. I would rate the leather an 8 out of 10. The seat bolsters are in good shape and not worn or blown out like most Camaros. The dash and all the plastics are in great shape. The car is EXTREMLEY clean for its year. The car was washed and waxed all the time, and it was garage kept. The stock wheels have been replaced with 1999 Corvette wheels with new tires. The car also features plenty of performance modifications and a custom stereo system.
Feel free to get a carfax report, but all it's going to tell you is that the car was bought from the dealer, has never been rented, wrecked, salvaged or repaired.
Performance modifications
Engine
·Professionally rebuilt 355 ci LT1 engine with 10k miles.
·All new rings, bearings, and gaskets.
·Forged 4.030" SpeedPro pistons, 11:1 compression
·Forged GM "Pink" rods
·Stock crank, balanced and polished
·Ported stock heads with 3-angle valve job
·Heads were ported by Elloitts Portworks and flow 254/191@.600
·Comp Cams cam 230/236 duration, .544"/.555", 112lsa
·Competition dual valve springs, Lightweight retainers and machined locks
·Comp Cams 1.6 ProMagnum rockers, "R" lifters, hardened pushrods
·NGK TR55 plugs, Taylor 8mm wires
·Electric water pump
·LT4 timing chain set
·Twin 52mm throttle body
·Ported MAF meter
·1LE intake elbow
·K&N FIPK cold air intake
·Free mods
Exhaust
·1 3/4" ceramic coated Hooker long tube headers
·3" y-pipe
·3" stainless steel SLP Loudmouth cat back
·Borla dual intercooled exhaust tips
Transmission
·SLP Torque Converter, Lock-Up, 2400 rpm
·Energy Suspension transmission mount
·Large transmission cooler
Electronics
·Alpine CDA-7863 CD player
·Polk Audio EX Series component 6.5" midrange speakers and tweeters
·10" MTX Thunder 6000 in a Thunderform box
·Sony 880 watt 5-channel amp
·DEI Viper car alarm
·Optima red top battery
Suspension and Body
·New shocks and struts
·Tubular sub frame connectors
·Suncost Creations SS hood
·RK Sport SS spoiler
·Car repainted 2-years ago at Hillard Ford dealership
·1999 silver Corvette wheels
·New 245/40/17 Goodyear F1 supercar front tires
·New 275/35/18 Goodyear F1 supercar rear tires
Patrs Recently Replaced
·Optispark, ignition coil, hood and hatch struts, shocks and struts, front brake pads and rotors, Optima battery, tires, spark plugs, battery cables, wiper blades, headlight, fog light, and turn signal bulbs, radiator.
A few more things you might want to know…
This car is unbelievably fast: The V8 is extremely powerful. It sticks in turns so well that I always let off the gas way before the tires can break loose. It's almost impossible to accelerate at full throttle; by the time I get the gas pedal to the floor, I'm already going too fast. And I have no idea where to try for a top speed run of 180+ MPH! In short, the car is already too fast for the road. Why spend $80,000+ or more when you can have all the fun possible for under $10,000? The car has current registration and inspection tags. The passenger window will need to be replaced, a new one is included. The check engine, airbag, and low coolant lights are on. The check engine light is on due to the removal of the smog pump. The air bag light is on due to a bad sensor, which I have the new one. It will also need a new low coolant sensor which is approx $30 from GM. The driver’s sun visor is broken and needs to be replaced. I reserve the right to end the auction early. I have over $20k of maintenance records and performance receipts, which are included with the car. Due to the camshaft and full exhaust the car is very loud from the outside, but it is not to loud in the inside of the car.
OK, so if the car is so great, why do I want to sell it? I am looking to buy a Viper. This was my first car and has been a great car, now I am looking to step up to something more exotic. If you have one and would like to trade let me know!
Old Apr 23, 2005 | 10:18 AM
Re: 1994 Chevrolet Camaro Z28, CLEAN, new motor 400hp $7,500!
ttt
Old Apr 23, 2005 | 12:13 PM
snakeatinZ's Avatar
I will enjoy seeing that cruise up and down the street. I hate to see ya selling the camaro, I wish I could afford it right now. I have see the car and it is very clean. A great find for whoever buys it.
Steve
Old Apr 23, 2005 | 01:38 PM
Thanks Steve! Stop by sometime...
Red Hawk 94
Mar 18, 2019 04:03 PM
NewsBot
Dec 24, 2014 11:05 PM
Collector Car
Dec 17, 2014 01:12 PM
NewsBot
Dec 3, 2014 12:30 PM
ChrisFrez
Nov 30, 2014 08:41 AM
