Front wheel bearing - ABS sensor
My bearing has the tiniest bit of slack in it... and the wheel is making a bit of a grinding noise when I come to a stop/start. I assume it's bad.
I've got it out. Can someone tell me if I should remove the ABS sensor housing from the hub and if so how, or does it come with the new assembly?
Re: Front wheel bearing - ABS sensor
The bearing and ABS assembly are all one peice, and if you buy a new "hub" you'll get all of it. So no dis-assembly required other than swapping the hub in and out.
Dave
Dave
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
z28projects4ever
133
Jul 26, 2002 01:54 AM
