Middle Atlantic New Jersey, New York, and Pennsylvania
Need Help Again...Car Acting up.....
Old Apr 19, 2005 | 11:20 AM
Hawk350's Avatar
(Buffalo Area F-Body owners......I need your help)
I am pulling my hair out every damn time I drive my car. I have the mods that are in my sig, heads and cam etc. This morning I was driving my car, and the car kinda buckled, then the check engine light came on. I checked the plugs over the weekend, they are clean. I dont have a scanner, so I cant check the code. Off the top of your heads, what would a sudden loss of be caused by? I happens sometimes, not all the time....and for a split second, then the check engine light comes on. On another note, when I had my car dyno tuned, the mechanic changed my plugs prior to the car being dynoed. He burned 3 sparkplug wires so they were arching. Would this totally throw off the tune? I need some help tryingt o figure this out before I sell the car this summer...any advice is much appreciated!!! If anyone can help me fix this, I will pay for your time....Thanks guys...
Old Apr 19, 2005 | 11:51 AM
Pampered-Z's Avatar
Re: Need Help Again...Car Acting up.....
Are the wires now good? I burned the #8 plug and it ached to the Knock module and gave the car fits! Double check the wire.
Also, I had allot of problems when I went to the 58MM TB. The voltage was way off. So solve the problem I had to elongate the wholes in the TPS so I could rotate it counter clockwise to get it to .57 volts at idle.
Old Apr 19, 2005 | 03:25 PM
'99 SS's Avatar
My brothers car did something similar after installing SLP's L/T headers on his car. It turned out to be a fouled plug, which they said may have been caused by his wires, causing an arch? He had to have a plug replaced twice.
When I installed my headers, I upgraded my plug wires, and I havne't had any problems (knock on wood)
Old Apr 19, 2005 | 04:09 PM
Hawk350's Avatar
I am running 8.5mm wires, installed on top of valve covers, so there is no way they are arching or burned. Any other ideas?
Old Apr 20, 2005 | 07:15 PM
GreekZ28's Avatar
I would check the opti.
Old Apr 20, 2005 | 08:15 PM
Hawk350's Avatar
it's not the opti. I had a club member drop y this morning and we scanned the pcm. 2 trouble codes appeard. code 1 was 83 which has to do with the reverse lockout and the other was code 84. I am going to check my fuses...but the scan
shoed everything was good, even the afr. Thanks again for your help Mark!!!!!
93 RedBird
Nov 15, 2015 08:24 AM
jayblev95
Sep 26, 2015 09:44 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
CARiD
Sep 7, 2015 08:21 AM
dkred94z
Aug 20, 2015 03:09 PM
