A way to disable KR at WOT?
Old Apr 18, 2005 | 07:47 PM
jchevy's Avatar
Is there a way to disable Knock retard when i go to WOT. And aslo have it add all the timing that has already been pulled, since it normally adds the timing back in slowly? I am using LT1edit.
Old Apr 18, 2005 | 11:08 PM
turbo_Z's Avatar
Re: A way to disable KR at WOT?
Yes.
Just look around for it. Might say KR in PE mode like tunercat but I dont work with LT1edit but assume all the same tables can be found. And the recovery rate is what you need to zero out to make the timing snap back to total advance in the event some KR is pulled.
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
SEOJustin
Sep 24, 2015 04:39 PM
95_lt1_z28
Aug 30, 2015 06:17 PM
Aug 7, 2015 08:52 AM
