installed a CD player in my g/f's car(have a problem)
Old Apr 18, 2005 | 12:56 AM
speed76demon's Avatar
she owns a 2000 sentra and a lot of the buttons were broke so she wanted another factory cd player. So I found one bought it thing looked brand new. Put it in everything works fine except it gets a read error with the cd's sometimes. This is with burnt cd's and regular store bought cd's. Any idea on what would cause this read error??
Old Apr 18, 2005 | 04:39 PM
Re: installed a CD player in my g/f's car(have a problem)
no ideas??
Old Apr 19, 2005 | 02:22 PM
come on guys nobody has any ideas on why it would play cd's sometimes but not other times??
Old Apr 20, 2005 | 03:47 AM
superadobo808's Avatar
The player could be dirty, get a cleaning kit and try it.
Old Apr 20, 2005 | 05:55 PM
alright it's worth a shot for sure
Old Apr 20, 2005 | 06:09 PM
Red97LT1's Avatar
The laser that reads the data off the cd could be bad also.
Old Apr 20, 2005 | 06:51 PM
Now I don't like u that better not be it otherwise i'll be pissed. I wonder why it didn't work at first then would kinda work then worked good for 1.5months then just stop working. GRR i'll try cleanin it and see what happens
Old Apr 21, 2005 | 01:07 AM
good luck man, tell us how it goes. You should start with the easy and cheap stuff first, then if you cant trouble shoot it, take it in, or get a new one.
Old Apr 21, 2005 | 04:37 PM
Red97LT1's Avatar
The reason I mentioned this is I had one acting somewhat the way you are explaining. it was under warranty and I got it fixed for free,but it was only 3 months old and it started funny. It could also be a loose connection inside the radio and it makes connections at times. Hope you figure it out.
Old Apr 21, 2005 | 06:08 PM
what would ya suggest if it was a loose connection inside the radio??
btw i'm trying the cleaner tonight
Old Apr 21, 2005 | 07:18 PM
Red97LT1's Avatar
You would have to take the radio apart and check the wires. It's not that hard to do if you take your time. I have done a couple that way(warranty was expired) to check some problems with other radios. Maybe you will get lucky and the cleaning will work. If the lens is dirty it won't be able to read the data off the cd. Good luck
Old Apr 22, 2005 | 11:47 PM
Bayer-Z28's Avatar
Head units can be fussy things....I had a Sony Expode (name says it all) and it would cut out every time the bass hit..
Old Apr 24, 2005 | 11:09 PM
well I used the cleaning cd and of course it read it fine and worked. Then we put a cd and it worked for about 2minutes then it quit. Then it hasn't been able to read any cd's since. I just don't know what the hell to do
Old Apr 27, 2005 | 01:24 PM
blknblu's Avatar
This is right, the laser could be bad, but instead of replacing the whole stereo,since you already have 2, the new and the old one, that I am assumeing are the same...just take the laser unit out of the old one and put it in the new one; if you get desperate.
Old Apr 27, 2005 | 10:41 PM
I am desperate got any info on how to do it??
