TH350 Conversion Ques.
Old Apr 16, 2005 | 04:12 PM
Ripcurl3249's Avatar
I have An A4 will i need a new flexplate with the TH350. What type of Torque converter do I get. Does the TH350 housing bolt up to the LT1 block or do i have to put the LT1 housing on it.
Old Apr 16, 2005 | 04:34 PM
blownbird01's Avatar
Re: TH350 Conversion Ques.
You dont need a new flexplate. The tranny will bolt up to the motor too. You'll have to modify your crossmember or buy an aftermarket one. You'll need the long tail shaft th350 if you want to keep the factory driveshaft. You'll need the lokar flexible dipstick. You'll have to buy a converter made for the th350. Mine is dual bolt pattern so it works with new and old flexplates. If you have the ability to weld, I would modify your crossmember. This will save you money and is very easy to do. You have to move the mount 1 inch further ahead. This is a pretty easy conversion.
Old Apr 17, 2005 | 06:30 PM
What do i do with the comp. Because they wont connect. Do i need a manaul valve body in the 350.
Old Apr 17, 2005 | 08:20 PM
You dont need a manual valve body, but you'll need to run a vaccum line to the trans. I'm running a manual in mine because I dont have vaccum at wot because of the blower. You'll need to have the computer tuned. The car will run fine without tuning but will cause a check engine light.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
