bmr k-member
Old Apr 15, 2005 | 09:32 AM
roxzee's Avatar
bmr k-member
i just installed a bmr k-member in my 94Z28 and found that the steering linkage just seems a few inches short from seating fully on steering rack. has anyone seen this issue, and what did you do....thanks
Old Apr 15, 2005 | 10:57 AM
OBE1 95Z28's Avatar
Re: bmr k-member
The steering linkage is designed to expand and contract (the rod slides inside the mating piece). It's common for them to freeze up. Spray some penitrating oil on it and tap it with a hammer.
Old Apr 16, 2005 | 07:48 AM
roxzee's Avatar
bmr k-member
i just installed a bmr k-member in my 94 Z28. during the installation i also installed jet hot long tube headers with y-pipe. the header on the driver's side seems to sit a little high and the y-pipe is not clearing the trans cross member brace. has any one seen this problem and what did you do. by the way jet hot is suppose to get back to me on monday. i called and informed them of my problem late yesterday. the pipe does not seem bent. i'm wondering if the k-member needs large spacers between the body and k-member to lower the drivetrain.
Old Apr 16, 2005 | 07:52 AM
roxzee's Avatar
Re: bmr k-member
thanks for the input!!
Old Apr 16, 2005 | 11:57 AM
whontime's Avatar
Re: bmr k-member
I can't really comment on the k-member, but I do have experience with the Hooker Y-pipe which is the same as the Jet Hot y-pipe. I had the same problem with the pipe not clearing the trans crossmember. I just took the car to my local exhaust guy and had it modified to fit. Just a note, the pipes seem hit or miss as far as fitment goes. They have fit some cars, but not others.
Old Apr 16, 2005 | 02:38 PM
Red96Lt1's Avatar
Re: bmr k-member
Yeah, the y pipe worked for me.
Old Apr 16, 2005 | 02:45 PM
roxzee's Avatar
Re: bmr k-member
was the y-pipe coated that you had modified to clear the trans cross member? how did they modify it? it looks like they have to bend it right at the flange area. the y-pipe comes with a flat spot that is suppose to clear the trans cross member on the driver's side but the header sits to high toward the floor board but not contacting the floor board that the y-pipe cannot even be bolted up to the header with the trans cross member connected. this is the same problem you had right?
Old Apr 16, 2005 | 06:55 PM
RunRiot's Avatar
Re: bmr k-member
I'm not so sure about this... on my 94 the "sliding" piece is held together with 2 plastic pins that are designed to break in the event of an impact so the steering column can collapse and reduce driver injury. BTW if it really needed to slide during normal use, it wouldn't freeze up.
I have the BMR K-member w/ low-mount steering rack brackets (to fit Canton pan) and mine was nowhere close to fitting, so I had a local fabrication shop make me a super-thick rag-joint eliminator (1.25" thick aluminum spacer) which lets it fit perfectly.
Oh, and as far as the crossmember goes, I had to cut the crossmember to get my y-pipe to fit. This was before I got the BMR K-member, you shouldn't need any spacers. In my experience, header manufacturers don't do a very good job of making sure the tubes are exactly the same on each set, so people end up with different clearance issues.
Old Apr 16, 2005 | 10:08 PM
roxzee's Avatar
Re: bmr k-member
thanks for all the input guys this website is awsome!!! i did a search on jet hot long tube headers on LT1's to find the drivers header collector flange either contacts the floor board or comes very close on most installs that were posted on this site. there were different methods that were taken to make the y-pipe work due to the clearance issues at the trans crossmember and driver's side header collector flange. methods like having custom y-pipes made to changing the orientation on the collector flange so that the flat side of the flange is at the top. not sure which method i will go with, but on monday i plan on taking the car down to a muffler shop with the hooker y-pipe to see if they can modify the y-pipe vs. purchasing a custom y-pipe. if i have to purchase a custom y-pipe, i will send the hooker y-pipe back to jet hot.
football4life
Oct 4, 2015 07:48 AM
JJOHNROE
Sep 8, 2015 05:39 PM
97blackformula
Aug 27, 2015 06:02 PM
TGGodfrey
Aug 18, 2015 06:08 PM
realistyc
Jul 28, 2015 07:32 PM
