I broke my Dash!!
Old Apr 14, 2005 | 11:00 PM
vonmoldy's Avatar
I broke my Dash!!
I took the top of my dash off and it was so britle it broke. its the big plasitc part right uder the windshield. Can I use one for a later model camaro? any suggestions for what to do?
Old Apr 14, 2005 | 11:19 PM
Tair's Avatar
Re: I broke my Dash!!
i did the exact same thing............luckily it was only a small corner, and i just glued it back. u might want to look for a new piece in a junkyard. it's pretty common for people to break this part....
Old Apr 14, 2005 | 11:21 PM
breakmyfootoff's Avatar
only the ones from 93 to 96 will fit, they changed them in 97. I believe they are about 100.00 new, or you might be able to score one in the for sale section, I think there are some cars being parted out on there now. Or you can patch it back together and live with the crack (i wouldn't though). Dont know how you took it out, but you should always remove the a-pillars before removing this piece. Hope that helps.
Old Apr 14, 2005 | 11:46 PM
Z95m6's Avatar
Yeah good advice thats how i shattered mine. I just upgraded to a TA dash with a good cover.
Old Apr 15, 2005 | 12:24 AM
vonmoldy's Avatar
I didnt know how to get a pillars off nor did I look how...but i broke it pretty good so i guess it doesnt matter how i did it cuz its broke! How do you get A pillars off?
Old Apr 15, 2005 | 01:30 PM
camaro777tom's Avatar
These are held in with a metal clip on the backside in 2 or 3 places. From what I've been told just pry them off.
Old Apr 15, 2005 | 02:50 PM
That is correct, they just pull off at kind of a downward angle, no tools should be necessary. The A pillars mount in some little grooves at the end of that top piece of the dash, it's not supposed to come out untill the A pillars are removed.
Old Apr 15, 2005 | 02:56 PM
BTW, I wasn't trying to critique you on how you took it out, just giving you a heads up for future installation and removal. Sometimes, if they are sun damaged enough you can still crack them when pulling them loose from the velcro even with the A pillars removed. Anyway, I wasn't trying to be a smartass, sorry if it came across that way
Old Apr 17, 2005 | 10:38 PM
RedRyder518's Avatar
You might as well go on and get a new one. When I cracked mine, I called every salvage yard in Houston and I could not find a good one or none of them had them. I guess you could try one of those F-body salvage yards...
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
Greg88
Sep 20, 2015 07:14 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
