Big HP guys with Competition engineering connectors
Car is in my shop now and im debating if i want to install these connectors or order different ones.
http://store.summitracing.com/defaul....asp&x=22&y=19
They weld in right to the crossmember bolts and run straight back from there to the rear of the car. They run right in the center of the each side of the floorpans. Cutting the floorpans for these will be a giant bitch and when they get they get to the back of the car they just cut off. Im thinking about cutting the bar on a 45 at the back and re welding them back in like an L so they connect to the rear subframe. I wanted to then run the down tubes from the cage right to where the subframes form the L. I was also debating on fabricating a rear crossmember for the connctors. I just want to know if anyone used these and how they did it. Thanks in advance guys.
BTW
502 BBC 13.1 aluminum headed roller motor 850+hp into a 92 RS
BTW
bossco
Nov 29, 2014 10:18 AM
