Speaker buzzing 94 z28 bose
Old Apr 13, 2005 | 11:11 PM
brendon444's Avatar
I have the three speaker bose system and blew the left front speak so i replaced it with a 6 1/2 inch jensen speaker which worked good for 2 months and then stoped working so i took the speaker out and noticed it was unpluged so i pluged it back in and it worked fine when the car was not running no buzzing at all....... but when i started the car up it would start buzzing very notecable and annoying at low volume and fade out as i turned it up. Tryed the other jensen speaker same one and it did the same thing so im pretty sure its not the speaker.
Weird part is the speaker will work great until the car is started. Ive had it working perfect before so i know its possible.. any help would be nice.
Old Apr 14, 2005 | 03:30 AM
'93 Z28's Avatar
Talking Re: Speaker buzzing 94 z28 bose
I believe the stock speakers get a different ohm, something like 2 ohms and the speakers I'll bet you tried are 4 ohms. I bet that's it. Try a good stock replacement speaker. I might have one if you need it. I'll have to venture into the abyss of my basement! The for sale section always has them, too.
Jas
;D
Old Apr 14, 2005 | 10:35 AM
brendon444's Avatar
ya i no that but ive had it working perfect before and it works fine when the car is turned off thats what puzzles me.
Old Apr 14, 2005 | 11:02 AM
Antz97ZNJ's Avatar
Im far from a guru of stereo systems but I know jensen is garbage
Old Apr 14, 2005 | 08:41 PM
brendon444's Avatar
yeah there not the best speakers but it works and it worked perfect before if only i could get the buz to go away. Even when the stereo is just on and no music playing the is there and wont go away till it is turned up or off.
Old Apr 14, 2005 | 11:30 PM
codyss's Avatar
BOSE GM speakers range from .75 ohms to 2 ohms.
You most likely fried the small BOSE amplifier. The buzzing is ignition pulses going through the stereo. A bad ground or a messed up amp will cause this.
Old Apr 16, 2005 | 02:43 PM
Red96Lt1's Avatar
Yeah, bose is not compatible with any other system. I just had to replace all 4 speakers because one blew. (which also requires an aftermarket head unit) because the dealer wanted $400 f#@%ing dollars for one speaker.
CamaroHeed
Mar 18, 2020 09:50 PM
Rod Bender
Jan 1, 2015 03:18 PM
MJ_Z28
Aug 7, 2002 07:15 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
96CamZ
Jul 27, 2002 04:13 PM
