spec steel flywheel?
Old Apr 11, 2005 | 06:54 PM
camaroguy94's Avatar
anyone know the weight of the spec steel flywheel? how much lighter than stock is it
Old Apr 11, 2005 | 07:19 PM
My Red 93Z-28's Avatar
Re: spec steel flywheel?
I just sold the stocker, so I don't know how much it weighs, but I think the package the spec flywheel came in said it was 22 lbs. I think. It said it on the ups sticker.
I can weigh it tomorrow to double check.
Old Apr 11, 2005 | 08:18 PM
thanks, i think the stock flywheel is 30lbs?
Old Apr 11, 2005 | 09:59 PM
Chomp's Avatar
while we're on the topic, how much of a difference does a lighter flywheel make, say, 22 vs 30 lbs?
I'll be using a built 4L60E with my LT1 soon..
Old Apr 13, 2005 | 06:32 PM
weighed the spec today, and it weighed in at about 25 lbs.
Chomp, why do you need a flywheel if you are using the 4l60E?
However, there is a difference although it will be under a 5 rwhp gain.
I think it has to do with less rotational mass, which means less work to turn the crank at the same speed.
Formula Steve
Sep 19, 2023 08:31 AM
karpetcm
Sep 29, 2015 10:08 AM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
